DNA Tuning (Australia)
Results 1 to 10 of 16
Thread: Modifying the front grille for increased air flow - pros & cons
    I've been toying with doing this for a while and as I'm about to install an S3 intercooler into the Tig I'll have the front end off.
    So my question is in relation to the lower grille which has half of it blocked off (see pic below). The top section is blanked off whereas the lower section is open. Just wondering about removing the top "blanking" and having air flow through the whole lower grille. Is there any issues with doing this? Plus side is better cooling but wondering if it's going to cause me any issues.
    OK so I might be answerig my own question here but on further research I've found there's a few Ford models with active grilles - little stepper motors which open and close off the grille.
    Theory goes that having the grille closed helps to warm up the car quicker to get to operating temps and also helps with fuel economy by reducing aero drag. However having the grille open obviously assists with cooling so there's a trade-off.
    Given I can only have 1 fixed position, do I stuff up my aero for extra cooling or not?
    Jun 2009
    I would say go for the extra cooling.
    The tig is brutal on aero anyway so it isn't going to add much more loss.
    Quote Originally Posted by team_v View Post
    Hahaha yes I probably won't stuff up the aero much more
    Jan 2012
    I rekon you can stuff up the aero.
    the whole reason why things are blocked off are to force the air to move through certain parts of the car. generally for maximum velocity at cruising speeds.
    if you mess with that and push air where its not really needed, you may go backwards and not get enough air flow through the radiator / AC condenser etc.
    May 2009
    Townsville,QLD
    hmm good answer VW fanatic..as my question was going to be, "Why is it there in the first place?"
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
    Quote Originally Posted by zei20t View Post
    Yeah which is why I asked the question. Just want to find out if anyone has done this sort of thing before and if they experienced these sorts of issues.
    Jan 2012
    only one way to find out
    if those black panels unclip or come out somehow. just remove them and see how it goes. but PLEASE monitor water and oil temps, especially over summer.
    Yeah the panel unclips - had it out when I installed the fly screen.
    Do you reckon I should do wind tunnel tests on a rolling road for before/after comparison too?
    Maybe I'll just run it and have a look at fuel consumption...
    Jan 2012
    why not try both? I would imagine a wind tunnel is harder to test. unless you have one, or access to one?
