Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Modifying the front grille for increased air flow - pros & cons
    Quote Originally Posted by zei20t View Post
    why not try both? I would imagine a wind tunnel is harder to test. unless you have one, or access to one?
    I was joking about the rolling road wind tunnel test. There are very few full-sized rolling road wind tunnels in existence and I don't think there even is one in Australia. It's what the F1 guys use when they want to sort things on their car.... I think my Tig is a way away from needing wind tunnel testing.
    So I think I'll just do the mod and then monitor it with my Autopolar FIS+
    Jan 2012
    I thought you might have worked at a University or something, and had access to one
    Unis may have a scale version with a fixed road but full size rolling road is massively expensive. For one you need to have huge fans to push a large volume of air at constant speed over the entire car surface. And then match air velocity with road speed. And keep all temperatures and pressures stable.
    So it's a large, complex and very expensive machine.
    I was hoping someone may have done something similar before and be able to tell me if it was going to work or if I was going to stuff things up.... Without using a wind tunnel of course.
    Jan 2012
    be easier to just get a wind tunnel
    Well after all that I pulled off the front bumper/grille on the weekend to install some new mesh and found that behind the blocked off section of grille there's a big chunk of polystyrene.
    I'm not sure what to do about it so I left it. It's probably there for impact resistance I imagine.
    Here's the full grille treatment:
    Jan 2012
    even if it does nothing, it looks good
