DNA Tuning (Australia)
Results 1 to 10 of 15
Thread: Mk7 R Res Delete
    Oct 2016
    Deagon, QLD
    Mk7 R Res Delete
    Where have people been buying their res delete pipes from and is it worth it sound wise?? I've been thinking of getting the Remus one but can't see too many others companies that sell it? Cheers!
    Jan 2012
    A good exhaust place can just put you in a good quality pipe, rather than spending money on an actual pipe. Rob Bliss in Geebung Brisbane did an excellent job on mine and the noise is fantastic.
    2015 Golf R. Lapiz Blue.
    Oct 2016
    Deagon, QLD
    Quote Originally Posted by Reedy View Post
    What did it set you back? Do you get any drone, I only want a bit more noise without is sounding obnoxious? I was thinking I liked the pre-made pipe as it is not welded and easier to revert back to stock if required.
    Jan 2012
    Funny you should say that. Rob Bliss made mine easy and to change. One side is bolted together and the other uses the sleeve. He the put a plate on the Resonator he took off so it could be bolted back in place. I think is was $150 all up. The noise is awesome, normal driving you would never know until you get in it the the car sounds like it should. I've coded my flaps to always stay open too. I like the drone but the kids sat in the back don't do I lines the spare wheel well with some sound deadening material, not sure if this helped. Over all drive normal and you would never know.
    Jan 2012
    Golf R Resonator Delete Flaps Open - YouTube
    Jan 2012
    Link to a thread I started with pictures of what I had done.
    Resonator Delete Options
    Oct 2016
    Deagon, QLD
    $150 makes sense to use them as the Remus pipe is $185 and then I would still need to fit it. Great idea to fit out the existing res to be able to be used later. I'll mention that to them and they might remember your install! I've tried the exhaust flaps permanently open for a month or so but found the drone too much. Between 1500 to 2000rpm felt like my ear drums would pop and thats where the car seems to sit when in traffic. It does sound much better at idle though.
    Jan 2012
    Yes Rob Bliss was very good and he's done many of these. Took him about an hour.
    Oct 2016
    Deagon, QLD
    Cheers for the advise. Your car sounds good, pretty much exactly what I want. I'll be making a phonecall to Rob soon to book it in.
    Mar 2014
    Newcastle, NSW
    I've got a genuine Audi one I can sell you. Turns out it doesn't fit my Wolfsburg wagon.
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
