DNA Tuning (Australia)
Results 1 to 8 of 8
Thread: Mk1 Golf. Distributor upgrade.?
    Aug 2007
    Liverpool
    I have a Mk1 Golf [ well actually Scirocco - same thing ] and it has the standard Distributor. The Engine also has Extractors and Twin Dellortos.
    So this Dizy should have vacuum advance and Vac retard.
    In fact mine has no hoses connected. When checking with a timing light, there seems to be very little advance movement on the timing.
    What is a good improvement for a Set up like this?
    [ should I just connect the vac adv ? ] If I do connect the vac adv - does it need to be in a [ " Vac closed Off " at idle position.?????? ]
    Thanks for " replies"
    Glenn....with Old Scirocco to replace old Beetle.
    Boronia VIC
    Send it off to Performance ignitions (Scorcher) Home
    Tell them about your motor and they'll set it up for mechanical advance and remove the vacuum can altogether.
    Costs about $100 and they'll test it out, rebuild it and re-curve it to suit your motor.
    They turn them around pretty quick too, usually about 48 hours.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Aug 2006
    Melbourne VIC
    Performance ignitions are good blokes!
    Mar 2010
    perth, W.A
    is there anything available as a direct upgrade? like an msd or something like that?
    Boronia VIC
    Yes. Something like a MSD Midget Dis 2 would completely replace the distributor. Midget DIS-2 Programmable Race Ignition - 6214
    You could use other MSD options too but you still need to fix the dizzy to fire it.
    Another option is to use the electronic dizzy out of a MK2 or Cabrio and have that modded. That at least gets rid of the points.
    All of the stuff that's sold for the 009 dizzys for the aircooled VWs will go into the Golf dizzys too, so there's plenty of options there.
    There's a couple of Jaycar kits too if you're handy with a soldering iron.
    7? MK1 Caddy
    12 Amarok
    Mar 2009
    thats exactly what was done to my dizzy...well worth it
    78 2-door 1.8 KR 16v - twin dellorto's
    Aug 2007
    Liverpool
    Thanks Peoples. I am going to take a look at that 009 I have lying around, then re-graphing will come after.
    Aug 2007
    Liverpool
    I put on some 8mm Silicon leads.
    Dismantled the old Dizzy with its Vacuum pots & tiny mechanical advance section. You know - drilled out the steel pin that holds the Gear on, had it in 50 pieces..... Found what restricts the Mechanical advance. Got out the grinder and modified the levers that turn the advance. Decided to try the 2 light springs for that quicker movement. Put it all together with lubrication, new pin in the gear drive.......
    It is Fantastic . !!! ..!!!
    No flat spots, Revs out hard to 6 k quickly and smoothly.... I suspect it goes better than with the electronic unit.
    The other useful mod I did was to cable from battery to relay {right next to battery} - then coil { total run 250mm in thick cable}.
    " so it gets very good power to ignition. " I noticed after doing just this small mod - the spark was noticibly better.
