The golf 2 1600cc engine is basically a smaller capacity of the 1800cc unit.
Distinguisable from the early engines by the water outlet being on the right, not the left.
It will be much easier to source a 1.8 engine in Australia.
Originally Posted by Golf Loon
Dude, I think the 1600 in the MK1 is a different beast to that in the MK2.
Yeah I know, it is. The Mk2 1.6 is a smaller capacity 1.8 Mk2 engine. Mk1 1.6s are very different.Originally Posted by h100vw
Sorry mate mis-read your first post. Thought you meant all 1600s had the top hose on the left, between 1 and 2.Originally Posted by Golf Loon
No worries. What would be the benefits of a 1.6 16v? would it be less laggy and have more power down low?
No benefit that I can see unless you needed to be under 1600 for a race series or something.
It'd rev it's arse off though being so short stroke.
Prolly gutless low down like a 1600 GTI nowt up to 4000.
I wouldn't go to all the trouble.
Use the 1600 block and build all the 16V guts into it maybe and retain the capacity.
Ok, so swapping heads is out. Looking for more power elsewhere then. The car has had a cam grind, 10,000 bore and new pistons, intercooler, oil cooler, cold air induction, pod filter, supercharger (toyota 4AGZE charger i think), bigger injectors and fuel pump, only thing i can think of is putting bigger valves in it. Any one got any ideas?
