Connector could be corroded, could be broken wire or not have good contact with the MAF pins.
See some simple tests. http://www.vwwatercooled.org.au/newf...72&postcount=2
Can you give us more details about the car?
could the maf sensor plug die instead of the maf sensor itself?
car doesnt run properly with it pluged, but when i unplug the maf it runs.. and i have changed to a new Maf sensor too..
MAF's probably still gone, my VR6 ran better with it removed when the MAF blew, and even better again with a new MAF.
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
i put a new maf but still didnt run.. and vagcom comes up with maf error..
so thats why im thinking it might be the wiring plug..
Did you put in a new MAF? or a secondhand one?
Did someone competent clear the codes and reset learned values on the car?
You are welcome to come past the shop this week and I`ll make it work for you if you like.
