Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 42
Thread: LSD talk. Wavetrac vs quaife vs mfactory vs peloquin.......thoughts/experiences?
  1. #31
    2.8 ~ 3k incl GST & transport + machining & fitting from memory
  2. #32
    Oct 2010
    Melbourne, VIC
    Is the machining that you mention the removal of the ring gear rivets and skimming the face of the ring gear before fitting?
    I'm more interested in the landed cost which would seem to be about $2k
    Resident grumpy old fart
  3. #33
    Depends, as you know - there are differences in the ring year & also the mounting boss from Polo to Polo, so we had the extra machining done (we used a sample Polo diff & gave them the specs), hence the price. They also attract (at the time) 15% duty & GST, so you won't land it for 2k unless you do it illegally.
  4. #34
    Oct 2010
    Melbourne, VIC
    So your fitting charge must be ~$500, then? Might be worth a (long) drive up...
    I know about the stupid 113/114mm ring gear diameter variation - how does the mounting boss vary?
  5. #35
    Feb 2007
    Brisvegas
    Sorry Guy are we talking a VWR diff from you or a custom job like Eddy's?
  6. #36
    SQS make diffs, we have used them before & they are good, we now use VWR versions as we have more say in the specifications we require. We have gone more towards using 2 way versions now (with heavy ramp on the deceleration) than one way, and as mentioned before, we can have a choice of plate materials.
    Mounting bosses vary on the ID.
    We don't do retail installations here - they are done @ Prestige & Performance in Coorparoo - about 100 metres from our workshop, you would need to contact them regarding installation costs!
  7. #37
    Oct 2010
    Melbourne, VIC
    Thanks for the info, Guy. I may have to get divorced to get a VWR LSD but at least I know it's there!
    Just for everyone's info, here is a description of the 'plate' type LSD that is being mentioned (I've always heard of it as the 'Salisbury' or 'Clutch Pack')
  8. #38
    Mar 2012
    Sydney NSW
    Just an update -
    Mfactory apparently does make metal plate lsd's to suit the manual mk5/6 Gtis - I have to confirm but if so I'm going for it
  9. #39
    Jul 2010
    Glen Waverley
    [QUOTE=bennjamin;918407]Just an update -
    Mfactory apparently does make metal plate lsd's to suit the manual mk5/6 Gtis - I have to confirm but if so I'm going for it[/QUOTE
    Any more info on this Mfactory hasnt responded to my inquiries on this.
  10. #40
    Jan 2014
    I know it's an old post, but if you want a plate/clutch, Kaaz do 020 and 02J centres at pretty reasonable prices for an extremely well built unit - sub $1500 landed. In regards to plate vs ATB/helical, I am a big fan of the Quaife and Wavetrac units. The traction increase is very noticeable and they are very well mannered for parking etc. Unless you're lifting driven wheels all the time in an extreme track machine I reckon the helical style options are all good!
    And MFactory do indeed seem to have plate options for the 02M 6-speed as of 2014.
    Specialised Gearbox and Differential Repairs and Upgrades
    Shot Peening, Isotropic Super-Finishing
    http://www.neatgearboxes.com.au
    http://www.facebook.com/neatgearboxes
