Hmmm, looks like not many people go down this path?
I'm currently investigating LSD options (for my DSG gearbox)
hi everyone.
This is aimed at my golf GTi mkv - but is relevant to most cars in this forum. So here it is.
LSD's. Looking for advice / experience from LOCAL AUSSIES that have them , have imported them or had installed etc.
Wavetrac and quaife are quite similar in price and operation.
The peolquin is slightly cheaper and often comes with a bolt set and bearings for the same price as the above units.
The mfactory unit - I just found on ebay. Having dealt with mfactory LSDs in hondas before there are no complaints. Considerably cheaper.
Anyway , who here in Oz has had one of the above units installed ? Hows it fairing ?
How much does/has it effected your driving ?
Roughly how much did it cost to get installed
And , any hook ups on a good priced site/s to get from?
etc etc
thanks for any thoughts
We have used Peloquin, Quaife, and have customers with Wavetrac's as well.
Depends on what you are after, all three of these (and the mfactory one) a torque biasing, which are OK & improve grip a bit. If you want them for track use, skip torque biasing & go straight to a plate differential - do it once - do it properly
Thanks Guy
Not much point spending a lot of money on torque biasing then...
Is there a plate differential unit available for the VW DSG?
And is it ok for normal street usage?
Hey Martin, there is, but there are several variations on the diff centre itself. We can work around that if we have donor parts!
If you are ever in Brisbane, you need to drive our new MK6 GTI stage 3+ DSG - It has a VWR diff in it (plate) and its perfectly mannered on the street. Took about 1000km's for the plates to bed in.
The VWR differentials are just on $3000, but personally they are 10 x better than a TBD.
I will be in QLD late March - sounds like another item to add to my "to do list"
(When the time comes, we could just pull mine out and put it on the bench)
Love the VWR gear - Thanks Guy!
Bug_racer:
He means the plate differentials are much more effective than torque biasing
From what I've read torque biasing is helpful up to a certain point...
(I guess you get what you pay for)
Exactly as I said 10 x better.
No loss of traction even with wheel lift, no bind / unbind mid corner when the TBD releases. On a tight track, its about 1.5 seconds quicker per 60 second lap.
You won't find a TBD used in any form of serious motorsport in FWD cars - even Mfactory make plate diffs for the Honda's for track use, but they don't make one for the VW's unfortunately.
I have spent a lot of time working with the APR crew on the setup & ramp angles on the two way differentials, and the single one we use for the street versions as well. And just had a week at Volkswagen Racing's HQ in the UK, and a big topic of discussion was diff setup, Carbon plates vs Metal plates, and how aggressive we can go on the street and still be able to park it in a shopping centre - All very interesting.
