Results 1 to 10 of 12
Thread: Lose APR stage 1 ECU tuning after replacing battery
    Nov 2010
    Hi guys,
    I am looking at having to replace the battery in a 2010 Golf R. Was wondering whether the stage 1 ECU programming would be lost if the battery was disconnected? Would it revert back to the default program?
    Nah, it'll still be there. Can only be removed by flashing the ECU. You might need to switch it back on though.
    Dec 2012
    Sutherland Shire, Sydney
    I've disconnected the battery several times, never lost the ECU tune, safe as...
    Dec 2006
    Kilsyth, VIC
    AFAIK with APR you usually have two/three tunes (or more). Stock, stage X and valet.
    By default when you disconnect and reconnect the battery it will go to Tune #1 which is usually stock, BUT you can just switch back to tune #2 to get your power vack
    Nov 2009
    I don't think the 2010 Golf R ECU supports multiple APR tunes (something to do with a limitation of the capacity available)? In which case, it's always tuned and there's no switching possible. A battery replacement won't have any effect in this case.
    Jan 2013
    Brisbane, The Gap
    even if it did, you wouldn't be charged for a re-tune. Your vin would be would be registered with APR.
    2011 MK6 GTI ED35
    APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
    MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
    If you have switching, it reverts back to program #1
    If you don't have switching, then nothing to worry about!
    Apr 2010
    I've had mine disconnected a few times and never recall it switching back to #1
    That said I'm driving on program 1 (stock) most of the time now anyway - so much smoother.
    I was goign to ask what the "default" program was. Obviously if you want to keep it away fro the attention of dealer you don't want it changing into "tune" mode ifthey disconnect the battery for whatever reason.
    Most dealers program stock in slot 1 by default - in case of battery disconnected it reverts to stock.
