Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Looking for power upgrade advice on stock '91 RV 1.8 GTI
    Aug 2009
    waikiki, WA
    Hi,
    I've recently acquired a mk2 1.8 RV 8V engined GTI golf. I am looking to raise the compression ratio with a wiseco piston set, and install a fast road high lift cam to the head, which is going to go off to the machine shop for porting, polishing, bigger valves and all new parts (springs, bucket tappets, valve stem seals etc).
    Once all this has been installed, i will have a 2.5" non-cat exhaust system installed. Also a decent K&N cone filter in place of the factory one....
    My questions are:
    What kind of power will the car make roughly from all this?
    Do i need to add any other componentry standalone ecu, Bigger injectors? for example..
    What is a sensible compression ratio when using a copper head gasket and ARP head bolts to maintain reliability?
    Do you recommend a particular cam manufacturer and/or profile?
    What valves both inlet and exhaust should i use to go bigger than stock?
    Any help will be greatly appreciated....
    exhaust manifold is a must to change!!! they are tiny!
    i am changing mine to a 2.0 bottom end., not sure what exhaust i am going to run yet.
    its never going to make massive power. if you want power fit a 16v engine
    a std RV is 100bhp, if i can get mine to 120bhp i will be happy.
    there is a few mk2 builds in the mk2 section, look up spyda's thread. he has done a fair bit to his mk2
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Gosford Central Coast NSW
    Quote Originally Posted by pommydubber View Post
    Hi,
    My questions are:
    all you have said will make a big difference. like velly said, its a must to ditch the crud std exhaust manifold. get some hottuning ebay headers for bang for buck, or there are other manifolds from other 8V vag cars that will work too, like mk3's, seat cordoba's, etc.
    i would think you'll turn better than 120hp no problem (especially considering the higher compression and decent cam).
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2006
    Orange NSW
    It'd be cheaper to throw in a 16v. They have more torque from idle than any of the GTI 8v's AND 139bhp standard.
    Aug 2009
    waikiki, WA
    Quote Originally Posted by velly_16v_cab View Post
    Thanks for the manifold advice Velly, Preen 59 & GLD GTI. If i did ditch the 8V unit in favour of a 16v what would i have to worry about in regards to plumming it in? like ECU, senders, etc....Plus where do i get a 16v unit here in Australia, especially WA!
    Jun 2006
    Orange NSW
    Whats your budget?
    How much power are you after?
    You can get decent power from the standard 8v engine but depending on your budget you have so many more options. 1.8l 16v, 2.0l 16v, 1.8l 20v turbo, 2.8l vr6...
    For the standard engine wiseco forged pistons are available off the shelf in 9.0:1, 10.5:1 and 13.4:1 compression ratio in 20, 40, 60 80 thou oversize from importperformanceparts.net Yours is 9.0:1 standard. 10.5:1 is good for the street.
    Supertech make great valves with wasted stems for improved flow in 1mm and 2mm oversize for inlet and exhaust. Standard valve sizes are 38mm inlet and 33mm exhaust on your head. They also make titanium retainers and heavy duty valve springs. INA make light weight hydraulic lifters aswell.
    I wouldn't worry about a copper head gasket with an NA engine the factory multi layer steel gaskets are a great option compared to the original. ARP head, rod and main studs are a safe option...
    Their are heaps of cam options and many different opinions on what is best. Techtonics Tuning, Schrick, Cat Cams, Piper etc the list goes on.. I have a Schrick 272 in my 1.9l 8v turbo and rate it highly.
    Golf Loon on here has a heap of engines to choose from if your keen for real power gains! A 1.8l 20v turbo conversion will easlily net 3oohp with a few easy mods, tuning and it will make many a HSV upset. but it will cost sum
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    Sep 2007
    if you're looking for plug and play, a seat ibiza cupra will have plenty of power. they're a 2.0 16v motor originally with 150hp. that would yield you easy power with stock management and a nice exhaust.
    getting big power out of a counterflow 8v is difficult. If it's a daily, you probably wouldn't want a cam with too much duration.
    i personally went with a techtonics tuning cam and am running high compression pistons in a counterflow 2.0 8v. but i dont really expect it to produce any sort of big power like you would with a more modern or FI engine.
    as mentioned before, budget plays a big role. i remember driving a 2.0 8v that just had a nice fresh head and i was just grinning all day. but having been in a couple of 20v frankensteins, there's a very big disparity between power/performance and cost.
    87' MK2 GTI
    13' MK7 TDI
    Aug 2009
    waikiki, WA
    Quote Originally Posted by twin eng, twin turbs View Post
    Whats your budget?
    Hi TwinTurbs,
    Thanks for asking the tough questions! My budget over the next 6 months for the engine and any additions to make it run properly is $5000 AU (Assuming the missus doesn't kill me first!).
    I would like to get as much power as possible for this 5K. But i recognise that big power kills 8V and 16V transmissions and clutches, plus stopping power needs to be upgraded. I can add several thousand to my 5K for this i presume! So i guess my next question is what power can an 8V or 16V transmission take reliably?
    As you mentioned the 20v Turbo route. This option is attractive but certain unknowns have been putting me off like:
    What transmission bolts onto the 20v T block in a MK2?
    What mods if any are necessary to hook up Transmission and engine in a MK2?
    Do i Ditch the 8V digifant ECU in favour of a standalone aftermarket ECU to run the thing?
    And lastly does 5K get anywhere near a 20VT conversion?
    Anything else i should know on this conversion?
    At present after talking on this forum to other members (leaving the 20vT out of the equation for the moment) the 16v 1.8 or 2.0 engine seems to be the way forward. I Can source one in running order for less than $1K and have $4k to spend on it and possibly an upgraded clutch. Am i right in assuming the 16v 1.8 PL motor will bolt onto my 020 8v gearbox?
    Assuming i go this route, i have priced all the following so far:
    16v PL 1.8 motor minus ancilliaries = $650 AU
    IP - High Compression Pistons (10.5:1), Rings, Bearings, Gaskets = $879A + Shipping
    IP - Stage 3 SPEC 16v Clutch (SV273) = $332A + Shipping
    IP - K1 Con-Rods Golf 1.8L H-section VW5669BBCB4-A = $389A + Shipping
    Local - Cylinder head Port, Polish, Cut Seats for oversize Valves, Skim Head if needed. = $1000AU
    IP - Supertech Valves +1mm Oversize = 16* $17 = $272A + Shipping
    IP - Performance Valve Springs = $162A + Shipping
    Autotech Performance Cams = 349.95A +Shipping
    Local - Custom Exhaust System including Manifold = $600A
    IP - ARP Head Bolts = $120A + Shipping
    $4753.95 not including shipping & unforseen Extras
    Jun 2006
    Orange NSW
    I aggree with Jay Jay, the 2.0 16v from a seat cupra with the 02a gearbox is the way to go on your budget. Keeping the factory engine management but doing all the mods you want to may go just over budget but be well worth it!
    I have personally smashed seven 020 8v and 16v gearboxes with my mk2 turbo and upgraded to an 02a gearbox from a seat cupra 2.0 16v. Which is the same internally as a vr6 except the bellhousing is different. If your going to drive your car hard you may smash your 020 8v box. The PL 16v will bolt up to 020 8v and 16v gearboxes but you need to have the 8v or 16v clutch to go with them as they are different sizes on the spline.
    20v wise, your 5k wont cut it unless you dont rebuild it.. I would ditch the digifant ecu and go stand alone management for sure, the power gain would be well worth it. A deisel 020 gearbox is different to the petrol 8v and 16v box and can handle more power, torque and bolt up to the 20v. The 02a box will fit in the mk2 no worries but your have to change to cable shift mechanism.
    Audi A4 B5 1.8t
    Camden, Sydney
    I`d go 020 TDI box with a 20V or 16v in a Mk2 and the 02A boxes are very heavy and unnecessary in all but the most extreme applications - like Martys
