DNA Tuning (Australia)
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: lets post some 400m times
  1. #31
    Apr 2006
    VW Race HQ - Sydney
    My g/f was there when you ran the cab . i was at work still
    nice times
  2. #32
    Golfwise Guest
    Standing quarters or whatever they are called seem to be a lot of money and effort for such a short time and the more effort and money spent the shorter the time and you don't have to make a car go around corners.
    I much prefer the challenge of a race circuit but I do respect the drag guys all the same.Its all in the engineering challenge of improving what the manufacturer started out with.
  3. #33
    Nov 2005
    15.553@not fast enough
    one of my runs.
    http://homepages.ihug.com.au/~kirium...s/MOV02904.MPG
    This is what it looks like when you've been lapped by a skanky MKI........oops I meant when there about to lap you.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
  4. #34
    Nov 2005
    newcastle
    twistage??
    The power I will be making will twist a mk1 on its first pass
    hey bug racer or any other knowledgable folks..
    im in the process of building a 1.9 8v for a hillclimbing mk1 which im hoping will benchtest around 200hp+ .. so i was wondering what you think would let go first on the mk1 chassis/engine mounts etc?
    also if you knew what mods/bracing would be needed to stop this?
    cheers
    TDI mk1 on the road!!
  5. #35
    Apr 2006
    VW Race HQ - Sydney
    Definately engine mounts . If you put a cage in that will help with chassis flex . Your best getting some solid engine mounts , and possibly bracing
  6. #36
    I've just put in a cross brace from control arm to arm very easy to make i'll post size's shortly when i lift the car in the next day or so i'll even try and take a pic.
    i have felt the the diff in front end rigidity turn in into corners feels a little better though knowing it's helping with keeping the front end together as in not wanting to do the splits if you know what i mean is assuring .
    cheers Dave
  7. #37
    Nov 2005
    newcastle
    solid as in solid? or solid as in tough?
    i can easily fit strut brace and front lower stress bar and illl probably reinforce the strut towers... any other major issues?
  8. #38
    Golfwise Guest
    Quote Originally Posted by Bug_racer
    Whats going to flex the chassis ?
    Surely not 200 hp which is a bit high for a 1.9.
  9. #39
    Apr 2006
    VW Race HQ - Sydney
    I knew a guy with a beetle once that had 150hp . After 3 years of racing the doors wouldnt close properly . I havent seen a mk1 with more than 150 without a roll cage yet so I guess I cant really comment there . Change engine mounts from rubber to polyurethane . A bit harsher but less chance of them shearing under torque load
  10. #40
    Nov 2005
    newcastle
    200??
    200hp is me being conservative... the guy who sold me the engine said it would bench test at 300! so im not getting my hopes up in case it disappoints!
    its a 1.6 bored and stroked to a 1.9, flat top pistons, balanced crank etc
    the head is audi i think as it has massive valves and high lift cam
    the head is polished and portmatched to fit the lynx manifolds, for which i have 2 twin 45 dellortos, plus matched extractors and a 2.5 inch exaust with side exit
    i'm still cleaning it up and saving up for some bits i need
    but ill let you guys know when its together and in something!... hopefully a nice stiff roll caged mk1
Similar Threads
  1. THE Mk2 Picture Thread
    By OEM G60 in forum Mk2 Golf & Jetta
    Last Post: 19-09-2023, 01:13 PM
  2. Polo delivery times - why so long?
    By peter_j_g in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 30-01-2007, 10:34 PM
  3. First post... and some help?
    By golfaholic in forum Mk3 Golf & Vento
    Last Post: 02-11-2006, 02:45 PM
  4. post pic of your own car
    By Red Mk1 in forum Mk1 Golf
    Last Post: 03-01-2006, 08:16 PM
