DNA Tuning (Australia)
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: K&N Filters
    Oct 2005
    Nowra, NSW
    K&N Filters
    Are they really worth the money? got one priced at the $110 mark recently.
    I've got a K&N panel filter in my current car (Not a vw sadly), it helped a little with the engine when you rev it out (revs out more freely) and it changed the engine note a little (but more throaty).
    Some people have put them in cars and dynoed them, I think the best I've read about is a 1-2kw increase...
    Oct 2005
    Nowra, NSW
    awesome my car will be even more throaty haha, Loon knows what im on about
    Yeh, well it helped mine a little bit and I dont see why it'd be different on a golf (my current ride is a rice burner).
    Oct 2005
    Dandenong North, Vic
    Yeah, in my opinion. Noticeable when you switch from a paper to gauze (K&N or other) a nicer induction sound knowing your definately less restrictive on the intake. Only comment I have on K&N is the rubber lining to fit inside the standard airbox seems a bit too thick. I found it difficult to close the airbox. I currently have a JR filter (blue dye colored instead of red for K&N) with a good fit in the standard air box. I dont know if its the same with other air boxes & K&N but for the MK2 GTI (33-2020 K&N part No.) this is what I can add to the thread. Company reply to my comment about the thick rubber was "to provide a better seal"
    As for the money, depends which type was quoted to you at $110 ? Just the filter element in standard air box or a cone kit ? My filter elements only costed around $60
    Mine was a very tight fit as well, I actually got the guys at the service to put it in in the end because I wasn't certain that it was sealing properly. They managed to get it in okay...
    Oct 2005
    Nowra, NSW
    It was a filter element in the box. I'm buying this though from evorobin though instead
    Feb 2007
    Perth, WA
    As has been said already, a K&N will help your engine suck in air easier.
    The good thing too about K&N's is that they have one for pretty much any make of car, even my old '86 Mazda 626 carby
    I am thinking of putting an apexi power intake into my golf vr6 instead though, why? To be a bit different, and because of this: http://mkiv.com/techarticles/filters_test/2/.
    Feb 2006
    Camberwell, Victoria
    You could get a BMC CDA for less than 200 pounds!
    Rock on BMC!!!
    Oct 2005
    Nowra, NSW
    installed it!
    Got to this point and thought the hell with it, who needs an air filter anyways
    ooooh shiny
    And all done, what pod filter officer? its just a sticker, its tricks the car into going faster.
    Many thanks to Evorobin for supplying me the setup.
Similar Threads
  1. Diesel Particulate Filters...
    By mk5mayhem in forum Mk5 Golf & Jetta
    Last Post: 10-10-2006, 07:49 PM
