DNA Tuning (Australia)
Results 1 to 8 of 8
Thread: JH code k-jet 1.8lt 8v turbo setup
    Nov 2005
    has anyone doen this in aust, what is needed???
    wabit
    Camden, Sydney
    My mate has a bolt on manifold and turbo setup to bolt onto an 8v Motor. I believe it uses the Turbo from a Golf TDI. He will sell for $1000.
    Have a read & look through this.
    Ton's of info on turboing CIS injected cars
    http://forums.vwvortex.com/zerothread?id=2484192
    Some of my parts are here & more to come for my turbo 8v daily driver in the build.
    Basically
    - Volvo 240T(didn't get them in Aust. but can be found on ebay & vw
    vortex classifieds) will require modified fuel lines as they positioned
    differently on the fuel distributor head
    - Audi 5000T Warm up regulator or Volvo 240T Warm up reg (same as above)
    - Distributor vacuum retard canistor or MSD boost timing master to retard the
    igniton as it comes on boost.
    - Exhaust manifold incl at least a 2.25-2.5" exhaust system,turbo of your
    choice(recommend T3 incl. oil line supply & drain into the sump. Water
    cooled turbo's not really needed but optional, just more pipes/hoses!),
    intercooler(not really needed for apllications up to 6-8psi but I would fit
    one anyway) & piping/misc clamps, gaskets, fitting's etc.
    This setup should see approx 170hp+ on a standard 1.8 8v running 8-10psi
    Tim
    Camden, Sydney
    Some early golf dissys have an advance and a retard on them.
    Jun 2006
    Orange NSW
    Thumbs up
    Hey Wabit i have performed such a conversion on my MK2 1.8 8v GTI, its not easy as far as tuning goes that was my biggest problem. I used a
    *wrx sti vf22roller bearing turbo
    *3" mandrel bent stainless exhaust
    *custom mild steel manifold using 1 1/4" steam pipe bends
    *800mm wide intercooler with 2" stainless plumbing
    *MK1 GTI inlet manifold with a MK2 throttle body
    Originally i recurved the dissy with retard on boost and a hobbs pressure switch to activate a fifth injector under boost, i had difficulty sourcing a larger warm up regulator and the engine leaned out in the top end revs. This setup saw 105kw atw on 10 psi, With standard internals and 10:1 compression. In the search for more power and frustrated i took off all the factory injection and fitted an EMS computer with EVO 5 injectors, with the dissy locked and an ignition module fitted the power jumped to 138 kw atw on 14 psi... I would recommend aftermarket injection
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    just found this on ebay... this guy sounds like he knows wat hes doing!
    http://cgi.ebay.com/ebaymotors/VW-8V...spagenameZWDVW
    Oct 2005
    Dandenong North, Vic
    Any good pics of your engines with the turbo setups ?
    syncro Guest
    Quote Originally Posted by Golf Loon
    All of them did.
Similar Threads
  1. callaway turbo kit!!!!!!!!!
    By WABIT in forum Mk1 Golf
    Last Post: 04-11-2005, 08:07 PM
