DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Intake with Giac tune
    Point Cook, Vic
    relocation for the MAF housing is only necessary if the design does away with the factory MAF housing.
    The factory MAF housings generally contains an airflow straightener which helps reduce any turbulence across the MAF.
    On a full replacement intake you will find the MAF will generally be relocated to after a bend which helps straighten out the airflow which can be quite turbulent after it passes through a pod filter
    FOLLOW US ON FACEBOOK
    Jan 2010
    hey tim, im still after an intake.
    do you think the apr carbonio will work out well with the giac?
    Sep 2011
    Quote Originally Posted by Tweeked View Post
    I have a VWR intake, on my GTI and it does just fine.... sounds like a vacuum cleaner on startup
    I had a BSC intake that was causing problems. I am now running a VWR intake and very happy with it so far.
    Though I cant say I get the Vacuum cleaner sound.
    MY12 GTI | GIAC Stage 2 | Eurojet Dump Pipe | BCS Pro CAI
    Point Cook, Vic
    There was a flaw in the MK6 GTI BCS intake design. The cross sectional area of the MAF was not correct causing the car to run too rich. We have since been modifying them to re-use the stock MAF housing and they are now working nicely. Anything that follows that path should most likely work just fine.
