Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: idiots guide to supercharging..
    Jun 2006
    Orange NSW
    Quote Originally Posted by WABIT View Post
    bolt on meaning stock internals and no engine work done.... just fabricate and tune is classified as bolt on
    wabit
    I wouldn't consider 'bolt on' to be fabricated parts. Bolt on in my way of thinking is off-the-shelf (or as good as) parts that are mass or semi-mass produced for a quick, easy installation. I'd consider fabricated parts with a unit designed for something else to be a custom job whether the engine is pulled apart or not.
    Oh, and it depends on you comp ratio as to whether you need to de-comp the donk. If its around 9.5:1 or lower you should be able to get away with it on reasonable boost.
    Aug 2007
    Liverpool
    I Love Superchargers. I have had one for many years and wanted to instal
    it on my ride [ just never got to finish it ].
    - Street Supercharging is best done very subtly. With low boost and good spark retard
    system - you will have no problems adding it to your standard motor.
    This will gain you Loads more Torque and awesome sound but not a Huge increase in power.
    Makes the driveability superb - and if driven right - will not break axles / CV 's / gear boxes
    but will make most V8's seem like slugs.
    Glenn
    Aug 2007
    Liverpool
    Here's a little tease,
    The camera I had back then was very poor.
    I had finished the manifold but then re-worked it.
    Then changed engine layout and had not done the alterations.......
    I am keeping the Blower in case I get keen and decide to put on
    the Rocco I'm getting.
    Glenn
