Results 1 to 10 of 15
Thread: I want more power from my TDI!!!!!!
    Has anyone done any ecu flashing, remap or upgrade for a Passat CC 125 TDI DSG?
    Can anyone recommend a product they have actually used?
    I'm looking at REVO or BLUEFIN just want peoples experiences with them or any others
    How much? Where from?
    2010 Passat CC TDI - Sat Nav, Panoramic Roof, Park Assist, Climate Controlled Seats, MDI, Reflex Silver, Kufatec Bluetooth.
    2012 BMW 328 ///M Sport - Alpine white, Sunroof, Navigation, Bi xenon, extended connectivity package, 19" ///M Sport alloys, ///M Sport package
    Jun 2009
    JMAC deals with bluefin.
    He is a member on here and could probably tell you more about them.
    Custom code also do some work with the diesel engines.
    They have a nifty DPF delete on the diesel golf 125.
    Contact Gavin View Profile: h100vw - VWWatercooled Australia as he is the Australian distributor for Custom Code
    What's a DPF delete?
    Jun 2009
    Removal of the Diesel particulate filter which allows more air to flow quicker through the system.
    With a Retune after the DPF delete the 125kw Diesel golf owners are set to see 170-180kw and 450-ish NMW of torque.
    Jan 2008
    Sunshine Coast
    "more air to flow quicker" c'mon!
    The DPF is a filter to trap soot in the exhaust. It does this like a cat, but one that has closed channels, and the incoming gas is forced through a porous wall into an outflowing channel. Traps solids nicely, but highly restrictive. Required for all diesel cars to meet euro V emissions. Some more info in the stickies in the Diesel section.
    The trapped soot is burnt off as temps rise, and if that doesn't occur via normal driving, the car forces a regeneration and dumps extra fuel late in the combustion cycle to heat the DPF up considerably to burn off that soot. Thing is it's never 100%, and several years down the track that DPF is going to permanently clog. That's the downside, but you're at least 100-150k off that as a minimum.
    Jun 2009
    Quote Originally Posted by Greg Roles View Post
    I just had a simple explanation until your inveitable reply
    Would be interesting to see how a deleted passat would go.
    Jan 2008
    Sunshine Coast
    Pretty good I reckon, the extra weight would tame the wheelspin and the 2000rpm torque spike nicely.
    Will removing the DPF void my warranty? Is it safe for the car? Is it legal? Will it make a different exhaust sound?
    Jun 2009
    DPF removal will void warranty.
    Not sure if it is legal or not, i know that the car has to meet those euro standards to be sold but i am not sure if it has to comply with them after it is sold.
    It should be safe, basically they just remove the DPF and retune the engine to allow for the decreased resistance.
    Not sure abot the exhaust note.
    Shouldn't affect it though.
    Hopefully Gavin or Greg can chime in with their greater wisdom.
