Fold the lead core over on itself as shown
Then place in the terminal
Now place the whole lot into either your MSD crimper or hand held crimper tool
Now squeeze like buggery. The great things about the hand held tool is it's on a ratchet & can't over tighten. Once it get's to its closed point, it can retract & you end up with the same crimping over & over
This is what is should look like
Bend the terminal at its bending point, 90 degrees to finish the lead end terminal job.
Then slide the boot end down over the lead end. Alittle bit of silicone can help.
Finished lead's with MSD lead separator's! Nice!
Installed setup. Very happy with it!
After having used this sort of lead set several times on different builds now, I don't think I'd go back to using a standard set of ignition leads. For the money, I reckon its worth going for the custom install, as they are not only great performing leads, they also look great when done properly.
