Anti-lift kit will apparently reduce axle tramp.
Basically it comes down to feathering the throttle and wider/sticker tyres.
I believe you can also boost the EDL/XDL setting via vagcom but not sure if that will help.
Hey Guys,
This has probs been asked before but cant seem to find it,
I have a 2011 mk6 gti with apr stage 1 and basically loose traction in 1st and second aswell as that nasty axle tramp off the line if you give it a bit!
Apart from new rubber what have others done to reduce/overcome this??
cheers
kos
MY11 GOLF GTI MK6 | CSG| DSG
APR Stage 1
Thanks Team V i have heard of the anti lift kit, would you know particular brands or sites to get them off?
also have heard alot about torque-arm mount inserts??? any idea if they would help?
APR Stage 1
The torque arm insert is basically a harder mount which reduces engine movment under acceleration/braking, it also gave smoother gear shifts.
I found it good for what it does but it also transferred vibrations through the car due to the harder compund and i couldn't live with that so i removed mine.
I believe most people go for a whiteline anti-lift kit.
Super Pro Lower Control Arms - Aparantely these are the sh*t. I willl get some soon when I have time.
eBay Australia: Buy new & used fashion, electronics & home d
Volvo S60 RD T6
