Results 1 to 5 of 5
Thread: how to fix traction issues on 2011 gti
    brisbane
    Hey Guys,
    This has probs been asked before but cant seem to find it,
    I have a 2011 mk6 gti with apr stage 1 and basically loose traction in 1st and second aswell as that nasty axle tramp off the line if you give it a bit!
    Apart from new rubber what have others done to reduce/overcome this??
    cheers
    kos
    MY11 GOLF GTI MK6 | CSG| DSG
    APR Stage 1
    Jun 2009
    Anti-lift kit will apparently reduce axle tramp.
    Basically it comes down to feathering the throttle and wider/sticker tyres.
    I believe you can also boost the EDL/XDL setting via vagcom but not sure if that will help.
    brisbane
    Thanks Team V i have heard of the anti lift kit, would you know particular brands or sites to get them off?
    also have heard alot about torque-arm mount inserts??? any idea if they would help?
    APR Stage 1
    Jun 2009
    The torque arm insert is basically a harder mount which reduces engine movment under acceleration/braking, it also gave smoother gear shifts.
    I found it good for what it does but it also transferred vibrations through the car due to the harder compund and i couldn't live with that so i removed mine.
    I believe most people go for a whiteline anti-lift kit.
    Nov 2009
    Super Pro Lower Control Arms - Aparantely these are the sh*t. I willl get some soon when I have time.
    eBay Australia: Buy new & used fashion, electronics & home d
    Volvo S60 RD T6
