I have had a few of these Passats and I am pretty sure they only have switches that tell the ECU the throttle is wot or closed and nothing in between. The load sensing is done by the airflow meter flap position.
While your google pulls up a lot of picture with TPS visible, all the ones I looked at are from VWvortex which ran a different version of the engine. It is a 2 stage TB not a single plate like a recent TB has.
My 90s reference was maybe a bit of a sweeping statement, the technology in that car is ancient.
Hopefully the OP can tell us what he has
You're absolutely right. Up to 1994 they had 3pins switch and from 1995 they had throttle valve control module with the 8pin connector.
