need some specs on the gauge and may be able to help out..
what size gauge (diameter etc)
electrice or mechanical??
what pressure ?
specific style of gauge or anything???
There are heaps of gauge manufacturers out there...
what pressure ?
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
Auto Meter Ultra-Lite Analog Gauges 4305 - SummitRacing.com
Summit Racing do lots of stuff, find what you want then check google I reckon.
Thanks gavin - the ones I found were all over US$200
I should have added the word 'affordable' my OP since the 30 psi gauges are far less than that.
Resident grumpy old fart
Speedhut have nice electronic gauges - in range of diam and pressures psi and bar.
Fullly customisable to suit you tastes.
Boost range: Gauges - Speedhut
They also do 0-60psi
I'm very happy with them.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
