Results 1 to 7 of 7
Thread: High pressure boost gauge?
    Oct 2010
    Melbourne, VIC
    Not sure if it belongs in this section but couldn't figure any better place
    Does anyone know of a high pressure boost gauge? All the ones that I'm finding only read up to 30psi.
    Resident grumpy old fart
    Jul 2009
    Geelong, Victoria
    sounds like you need a train steam pressure gauge!
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Jul 2005
    need some specs on the gauge and may be able to help out..
    what size gauge (diameter etc)
    electrice or mechanical??
    what pressure ?
    specific style of gauge or anything???
    There are heaps of gauge manufacturers out there...
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Quote Originally Posted by blutopless2 View Post
    what pressure ?
    Auto Meter Ultra-Lite Analog Gauges 4305 - SummitRacing.com
    Summit Racing do lots of stuff, find what you want then check google I reckon.
    Oct 2010
    Melbourne, VIC
    Thanks gavin - the ones I found were all over US$200
    I should have added the word 'affordable' my OP since the 30 psi gauges are far less than that.
    Nov 2005
    Sydney NSW
    Speedhut have nice electronic gauges - in range of diam and pressures psi and bar.
    Fullly customisable to suit you tastes.
    Boost range: Gauges - Speedhut
    They also do 0-60psi
    I'm very happy with them.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    I know I've seen this done but is there any way to get boost pressure in MFD apart from buying a kufatec BT unit?
