View Poll Results: What sort of system should I run the Heron motor on
Voters
15. You may not vote on this poll
  • K-Jetronic
    12 80.00%
  • Weber Carb
    3 20.00%
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Heron Motor (Carb v KJet)
    Jul 2006
    Afternoon chaps and chapettes,
    Ok so the decision has been made for my project, it will be a 1.6 Heron motor out of the early Mk1 GTI's running a 5sp manual box.
    The head has apparently got a little work to it (to be confirmed exactly what) and I want to run a mild cam for some nice mid range torque and power.
    The question now is....
    Do I run KJET or Weber Carbs?
    I will be buying an early Cabby parts car so has all the lines, cabby fuel tank and engine/box. This will make it easier to go to the KJET route esp as its all there but I still would love to have carbs as they just sound so damn TOUGH! My thing with the carbs is that the carb will be sitting at the rear so will only be sucking in hot air and when we move back to the gold coast it will be hot MOIST air.. prob not too good an idea.
    What are you peoples opinions on this? Am I just trying to convince myself or what?
    Jun 2007
    Eastern Suburbs Melbourne
    Kjet, that way it's closer to GTI spec!
    carbs are generally never ending fiddling. + they look better on cross flow heads..
    i like volkswagens
    Jun 2006
    Orange NSW
    Kjet is (within reason) a one off tune. Get it fitted, get it tuned by someone competent and forget about it. Very simple. Good fuel economy etc etc...
    I'd probably just do the Kjet thing, messy as it is. Far simpler if you have a complete dressed engine.
    You'll be a bit annoyed with carbies if you're not used to them. Injection is better for a daily driver, in my opinion.
    Perth. WA
    Would go K jet, stays in tune as Preeny commented, and better milage for the power delivered. ( less fiddle time, more time behind the wheel )
    Have you a 1.6 heron engine or just the head ?
    Got about 3 of them here but they all need new pistons ( oversize ) you can get them from Wossner i believe.
    Valves are slightly longer from std 1.6 items as well from memory.
    Have most of the fuel system as well ( several sets)
    In hot weather, K jet can have fuel evaporation probs as well ( inlet being directly above the exhaust as you well know..) but there is a pretty easy fix for this...
    pix....
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Camden, Sydney
    I have a few Heron motors and heads too if you feel the need.
    Jul 2006
    Quote Originally Posted by roccodingo View Post
    pix....
    Hey mate, have not got it yet but hopefully I will soon.
    It is in a Cabby GLI with full GTI running gear so should be good fun
    Nov 2005
    hey dude, all GLI and GTI cabbys came out 1.8lt.... im alsoo pretty sure they didnt comeout as a herron engine
    dom
    Boronia VIC
    I'd say K-Jet for the street for all the reasons above.
    K-Jet actually makes good horsepower if it's all setup properly.
    Carbs are great and will probably make a little more horsepower but at the cost of noise, fuel, starting issues, non standard aircleaners etc etc.
    I've run both on the road and on the track, I'd say the carbs, professionally rebuilt and dyno tuned are better than my home tuned but functional K-Jet provided you can put up with all that goes with them.YMMV.
    On a fairly stock Herron 1600 either will go pretty hard IMHO.
    Every thing's a trade off.
    In your case I'd probably just go with whatever's more convenient to source and install.
    Pete
    Jul 2006
    Well, it comes with KJET and all the lines and cabby tank so will prob be a pretty easy conversion.
    The Cabby tank is a pretty easy swap I take it?
    Dom: Not sure what the go is but I was told it is a Heron engine?
    Perth. WA
    have a look at the front of the head, if the top coolant flange from the radiator goes between #3 & #4 Cyl its a 1.8 ( not heron head )
    In the pic above the engine is a 1.8 Inj + 0.5 overbore.
    If its between #1 & #2 then it could be a heron head or std type inj head.( or carb as in this case)
    heron head, note NO combustion chamber ..
    Thats because the combustion chamber is infact the bowl in the crown of the piston...
    Hope that gets you on the right track..
    You may need to check what fuel tank the cabby ( donor) has, as the later cars had a larger tank than the earlier models..( Think the stiffener across the front of the spare wheel tub interferes with the latter type tanks, anyone confirm this ??)
    Cheers,
    Grant...
