Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: HELP! car running on 3
    Quote Originally Posted by Jimmymac View Post
    yeah it is 1342 and like i said earlier if you get 1 right the rest follows as per threaded. Print it off as this rule of thumb works for EVERY 4 cyl engine , is this a freshly built engine ?????? put a little squirt of oil down that bore if it is mate and unstick the rings.
    Good luck and keep us posted.
    JMac
    i dont know how long ago but it was rebuilt sometime and bored to an 1800.
    #3 piston is moving up and down alright, Dad stuck his finger over the open spark plug hole when we were checking spark and you could here the amounts of suction on his finger, not exactly a great test but good to see there is some compression there
    Boronia VIC
    This is a new motor right? What kind? Hydraulic lifters?
    I remember you had the timing belt off for something was it to change the cam? Did you remove any buckets?
    You might have a stuck lifter that hasn't pumped up yet although they're pretty clattery when that happens.
    Is there plenty of oil in the motor?
    Annthing I've forgotten ?
    Pete
    its a 1600 bored to 1800 with an early pre emissions head, plenty of oil about 3/4 full, new filter.
    no removal of buckets, or anything like that and sorted the timing to TDC when i got the new cam belt on so no worries there, it did momentarily spark to 4 then back to 3, will explore all options tommroow when building the exhaust
    Aug 2007
    Yeah valves not seating perhaps like Peter said, mate just as a test make sure on the cap 4 is across from 1 im sure it is as you have it running at least on 3. now just swap number 3 and 2 around at the plugs
    What you got????
    Alba European
    Jun 2007
    Eastern Suburbs Melbourne
    it seemed to have compression, when we were turning it over (without the spark plug in)
    I think we'll have to check the vaccum lines, mainly off the manifold, and then if still no luck, do a compression test.,
    i like volkswagens
    Aug 2007
    Swap 2 and 3 around and see what you got
    Alba European
    ill definately try that tommorow hopefully that'll get it running.
    Aug 2007
    Good luck man keep us posted.
    Alba European
    Boronia VIC
    Yep, good luck. Let us know how it works out.
    Pete
    thanks fellas tell you tommorow
