Results 1 to 2 of 2
Thread: GT 1.4 what is the box under the engine cover?
    Closet Diesel Owners Club President.
    Hi guys,
    What is the box attached to the engine cover doing? It seems to contain vacuum and has a hose coming off of it on the right hand corner of the engine cover with goes to an electronic sensor of some sort further to the left of the engine.
    Is this something you can plug up/remove?
    I plugged up the hose going to the box under the engine cover and it feels and looks based on the boost needle as though the needle stays higher for longer and also does not swoosh up and down so much.
    Maybe the hose goes to a boost bleeding system for the supercharger... I will have a more detailed look where it goes under the bonnet later.
