DNA Tuning (Australia)
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 92
Thread: Home made Turbo kits.
    Feb 2007
    Bunyip, Victoria
    I'm toying with the idea of a low blow turbo kit on the golf, just to get it hustling a bit harder.
    I'm thinking about using a turbo from a WRX, or 200sx, with a larger wastegate, to handle the exhaust volumes of the V6, and to drop the boost a bit, to around 4 pound. I figuered the standard maf could handle that in a draw though design, and the injectors would keep up. would need to chip it or somthing. that will be the hardest part i recon. I'm already running a full 2.5" exhaust system so thats fine.
    I'd proply need an intercooler, but stuffed if i know how im gunna get into my bumper, its damn tight.
    not aiming for massive power figures, just more tourque, a bit more power, and a consistant 14 sec quarter.
    any ideas?
    You can fit a vortec (vortech) charger without an intercooler at about 6PSI IIRC and get 300hp.
    I have been in one and it flew!
    Feb 2007
    Bunyip, Victoria
    but then i'd have to buy things.
    I wanna make somthing.
    I could probly stuff 6psi in un intercooled, that would help packaging, but can the stock injectors handle it?
    h100vw, can you program VR6's?
    Feb 2007
    Bunyip, Victoria
    what car could i steal a turbo from?
    Point Cook, Vic
    guys in the US use stock injectors at 6psi.
    If you wanted to do it ghetto styles maybe look at a rising rate fpr? Not sure how the ECU would respond to that but i know some companies go that route instead of a proper ECU tune
    FOLLOW US ON FACEBOOK
    Feb 2007
    Bunyip, Victoria
    i have had a thought, re turbo lag.
    There wouldn't be any loss of power while the turbo is off boost, would there. I'm not dropping the compression, so it should make the same power when off boost, yeah? so when the turbo comes on, its just extra power and torque. so it SHOULD be the same car to drive quietly, then add throttle, gain power.
    So in summery, the turbo lag would be negligible, and even when off boost, the car will be just as fast.
    Am i right?
    Jun 2006
    Orange NSW
    Put a puffer on it. More drivable, no lag. No heat issues. Don't have to modify your exhaust. A little vortec puffer would be the way to go imo. And it would probably be more fuel efficient for normal driving because the engine will be working more efficiently.
    Quote Originally Posted by ScienceVR6 View Post
    Custom-Code do chips for std VRs but I am not aware of them doing one for a forced induction one.
    I think it would be tough for them to do remotely.
    GIAC do the chip for the Vortech kits. They do mention larger MAFs and bigger injectors in this tuning guide.
    http://www.eurotuner.com/techarticle...0_to_4000.html
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by Tim View Post
    so rather than tune the ecu, let the R R F R add more fuel?
    Jun 2007
    Eastern Suburbs Melbourne
    best bet would be to mimick a pre packaged bolt on kit. that way you have a general guide as to what works and what does etc etc
    i like volkswagens
