Fuel additives, special fuel etc have zero effect on upper intake / intake valve stem gunk, as fuel is added directly to the cylinder. Seafoam helps reduce the gunk that eventually builds up on the intake valves like this. Once baked onto a hot intake valve, like the poster shows, you have to physically remove it. V-power etc do not get into your intake on direct injection cars, unless they have some pre injectors often to combat this exact problem.
Catch cans from new, or regular seafoam / upper intake cleaner is the only option, apart from pretending it's not there.
