DNA Tuning (Australia)
Page 24 of 47 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 466
Thread: The great big MK6 Golf 118TSI tuning thread
  1. #231
    Apr 2010
    Thanks. At a point where I'm not sure if I want to treat the current car or endeavour to upgrade to used Mk6 GTI/R now that depreciation has well and truly kicked in.
  2. #232
    Nov 2014
    Toowoomba, QLD
    Is DSG rated at 250 Nm? Will it be problem to get more power/torque out from 118 tsi engine?
  3. #233
    Dec 2006
    Kilsyth, VIC
    I always thought the DQ250 (DSG) and MQ250 (Manual) were rated for 250Nm (and the DQ/MQ350's at 350Nm).
    Of course plenty of people are putting plenty more power through them than that and they seem to hold up pretty well (my MQ250 included).
    Bottom line, yes you are putting in more power than the factory and should go in knowing that things could break and you'd be up for a repair bill if that ever happens... but then that's all part and parcel of the risk when tuning. Even if the gearbox is OK there is always the clutch plate.. or the drive shafts... or any other part of the driveline too
    Hopefully someone with some real knowledge of the DSG can chime in for you though.
  4. #234
    Apr 2010
    If you drive with mechanical sympathy it'll be fine. i.e. don't request all the torques suddenly.
  5. #235
    Trinidad and Tobago
    If torque was really an issue we would see a ton of threads about broken dq200 clutches from people with stage 1 and stage 2.
    We don't. Stage 3 and above however I've read where the clutches start to slip.
  6. #236
    Oct 2014
    Slipped into a google tuning vortex the other day and dug up these gems...
    BullX 1.4 Twincharger Downpipe Euro 399
    https://www.hg-motorsport.de/shop/pr...-Downpipe.html
    What appears to resemble an S3 intercooler on Ebay from China AUD 385 delivered
    VW Golf GTI 06 10 2 0T Turbo MK5 Fmic Intercooler KIT Version 2 RED | eBay
    The intercooler appears to have different core thickness and outlet diameter to the stock S3 part 1K0145803P
    Does anyone have any experience with these oversize units or the stock S3 units with a 118TSI?
  7. #237
    Apr 2010
    I've got the S3 intercooler on my car. Had to cut the end fitting off and stretch the pipe a little and use a more traditional hose clamp. Would be nice to go silicone but never found anything the right shape (all designed for the GTI/R, not the 118 ). Was mostly to help the car survive summer.
  8. #238
    Oct 2014
    Yeah, ok. Do you know how thick the intercooler core is on the part you installed? My concern is that the cheap ones advertised are about 57mm whereas the genuine part is 40mm. Looking at the space with the stock intercooler in the 118TSI there doesn't look to be much room...
  9. #239
    Trinidad and Tobago
    Most likely it will fit once the connection points line up as there is room in that area of the car for wider parts but what is of greater importance imo is lag due to an intercooler being too large.
    Twintercooler installations on the 118tsi has led to increased lag in the supercharger portion of the band.
  10. #240
    Trinidad and Tobago
    Quote Originally Posted by Mk R View Post
    What's the part number for your stock intercooler?
    Here are my measurements for my stock versus s3 intercooler.
    Core for s3 intercooler is 37 mm.
    The great big MK6 Golf 118TSI tuning thread-imageuploadedbytapatalk1455962830-009392-jpg
