I always thought the DQ250 (DSG) and MQ250 (Manual) were rated for 250Nm (and the DQ/MQ350's at 350Nm).
Of course plenty of people are putting plenty more power through them than that and they seem to hold up pretty well (my MQ250 included).
Bottom line, yes you are putting in more power than the factory and should go in knowing that things could break and you'd be up for a repair bill if that ever happens... but then that's all part and parcel of the risk when tuning. Even if the gearbox is OK there is always the clutch plate.. or the drive shafts... or any other part of the driveline too
Hopefully someone with some real knowledge of the DSG can chime in for you though.
