Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 75
Thread: Golf R stage 4 build well underway
    Anna the workshop fairy comes to help out from time to time
    Jan 2010
    Springwood
    We are making some of our own chassis components this year, including alloy front control arms with adjustable castor, from last year.
    Hi Guy,
    Any particular reason for the castor adjustment?
    I recall you mentioned that castor kit in the R made it vague at high speeds, and camber was actually preferred...
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
    Apr 2010
    Melbourne, Australia
    nice work guy
    Quote Originally Posted by Mr_Bob View Post
    Hi Guy,
    We have done some different stuff with this car as far as adjustment settings are concerned. we probably have a few more options with our new control arms & adjustable ball joints. Castor is there if required - if not, we dial it out we can achieve 13mm more lower offset (camber) if required, coupled with our 3.3 degrees maximum at the top, we are going to work more at the lower arm end. Our new sway bars should work well too - we have dialed the specs, hopefully we will get a chance to test shortly (waiting on a gearbox seal.....)
    Feb 2009
    Sydney, Australia
    This thread, and some of the photos Arin posted elsewhere, kept me up at about 3am when I woke up this morning, lol. Just thinking about all the possibilities. Guy, do you mind if I post some of the "engine/kit parts laying on the floor" photos that Arin posted? Or maybe you'd like to post them?
    Anyway, I was thinking... is the capacity of the engine still standard (1984cc)? Or has it increased a bit?
    Can you talk at all yet about any of the internal changes, or turbo changes etc?
    May 2011
    OH! camber! I need some of that really bad, do you sell camber kits?
    2011 Golf R *insert mod list here*
    Apr 2010
    Hey Guy.
    Will your sways be adjustable?
    Also do you know yet what your lower control arms will rrp for at this stage?
    Fab
    Quote Originally Posted by worx View Post
    We are working on the lower control arms / ball joints / hub carriers to get adjustability.
    We run Cross Coilovers on our Golfs, they have built in camber top mounts that give great adjustability. If you want a good track setup, its best to start with something like this!
    Quote Originally Posted by Fab_R View Post
    Hey Guy.
    Fab
    3 settings front & rear for our swaybars - we will have the stiffness numbers out soon.
    No idea on the cost of the arms yet - hopefully soon.
    May 2011
    I don't know if I want to adjust the top to allow more camber, won't that throw out the geometry of the suspension?
