Results 1 to 10 of 14
Thread: Golf R down pipe ceramic coat or not
    Apr 2013
    The Gap, Queensland
    Guys
    Have just taken delivery of my down pipe and want to get your experienced thoughts on weather it is worth ceramic coating it before installation.
    Paul
    I used to have a ceramic coated downpipe on my R - personally i wouldnt spend the money again. Never noticed any difference in heat/performance, and despite costing approx $250 for the coating, it started to chip/peel off in spots within about 6-8months of street use.
    Ive now got a different down pipe and i just left this one raw stainless steel.
    Dec 2008
    Sydney/Canberra
    The only reason you'd do it is if you're worried about melting everything within the vicinity of the downpipe.
    If it were me, I'd fit it as is, and maybe keep an eye on things.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2013
    The Gap, Queensland
    Thanks guys for the feedback
    Out of interest - which down pipe did you choose?
    Apr 2013
    The Gap, Queensland
    Went with 42DD
    Apr 2013
    The Gap, Queensland
    Lucas_R do you know if I will need a o2 sensor spacer to avoid a cel fault?
    Quote Originally Posted by prh1973 View Post
    Most likely - unless you have the tune modified to take this into account.
    Oct 2013
    Went with 42DD
    The 42DD is made of mild steel. I would get it coated just to stop it rusting away on you. Unless you want to change your dump pipes as ofter as lucas doesGolf R down pipe ceramic coat or not
    Otherwise it doesnt make a big difference. If you have a tune you wont need to worry about the o2 sensor.
    MY11 CW Golf RIntake, Tune, DP, DV+Superpro arms and ALKCustom 4" tipsTWM Short Shifter
    Point Cook, Vic
    It wont rust away. It will just look ugly.
    FOLLOW US ON FACEBOOK
