DNA Tuning (Australia)
Results 1 to 6 of 6
Thread: Golf Front Struts and Springs
    Camden, Sydney
    Check this out. From right to Left
    Stock Golf Mk1 Strut
    GTI Mk1 Strut
    Seat Cordoba 1995 Front strut. Top is different, but interchanges with the golf one.
    I`m thinking mount my lowered springs to the Cordoba Strut and the near new, bigger shocker?
    What do you reckon guys?
    PERTH
    i reackon you should try to do it, are the hub bolts and camber bolts line up to the cordoba shocks, will it give the same ride height as the originals?
    the golf is not dead.
    Jul 2005
    Melbourne, Williamstown
    Don't do it if you already haven't. The cordoba is a far heavier car and the internal valving of the seat shocks will be totally different and would almost make your mk1 undrivable.
    I once asked a friend of mine(suspension expert) if I could put my heavily uprated mk1 suspension into my mk2 after I blew the front shocks and he said no way. Even though the mk1 and mk2 are more closely related than the seat and mk1.
    mk2 GTi 16v
    Corrado G60
    Camden, Sydney
    Yeah I got a good set of bilsteins in the end for my Mk1
    Was taking a Mk2 apart today and the front shocks and springs are the same as the Seat ones.
    imported_brackie Guest
    Questions 1 and 2
    Question 1...How do you tell if your Mk1 struts are the cartridge-insert type (ones that don't have to have the strut removed to replace them) or the difficult ones?
    Question 2... Can you get bent struts straightened?
    Golfwise Guest
    Struts
    All mk1 have removeable inserts.
    No you can't straighten them.
    Suspension is VERY important part of a car and for safety sake one should always use good parts.
    SEAT and any other later Golf struts may look the same but the shocker insert is a lot longer.
