Results 1 to 10 of 19
Thread: G60 supcharger
    Jun 2006
    Quote Originally Posted by aussieg60 View Post
    Standard pullies on a G (78mm) run at about 70% of its maximum rotation before it can go out of balance. I think the max rpm of the G is around 15k.
    Smaller pullies require more regular rebuilds. A pulley smaller than 65mm can throw the charger out of balance if motor is reved above 6K and is then more likely to explode. Stay within 68mm + pullies, charger should be ok if motor is not reved to high.
    As for unreliability concerns, it pays to have a good air filter to stop dirt entering the charger making a grinding paste in the charger.
    I see you have a nice setup in ur mk2, is it an original G60 or u did the conversion?
    what im concerned about is mounting of the charger, obviously needs to be dead set aligned up with perfect angle to the driven pulley/axle
    also, would the fuel delivery present a problem, would I need to play around with fuel re mapping or even bigger injection or stronger pump?
    cheers mate
    good lookin engine bay
    Jul 2005
    Melbourne, Williamstown
    G laders are not as efficient as some other types of superchargers. And not as reliable.
    Personally I'd save for a twin screw as they're the most efficient(positive displacement). As machining technology has improved the efficiency of screw type charges has really picked up and maintanece issues has gone down. That said they're still more expensive to buy.
    mk2 GTi 16v
    Corrado G60
    Jul 2005
    If mounting is an issue people usually choose the centrifugal type, you see lots of those on mk3 vr6's in the UK. But they're not a positive displacement type meaning they act like a turbo and they suffer from a lack of low down torque.
    mk2 GTi 16v
    Corrado G60
    Oct 2005
    Dandenong North, Vic
    Efficiency of the G is rated at about 65% which to me isnt to bad from that era. Capable of producing up to 15psi with a 68mm pulley.
    As for the twin screws, they would be great and possibly 80% efficient. Bloody loud too.
    Check out Bahn Brenner, maybe there's a twin screw setup for you MK3
    MK2 GTI G60
    Jun 2006
    Guaranteed to outperform all available 8V turbo kits.
    The complete bolt-on Stage I kit bumps up your power by nearly 60% 177+ bhp 180 Torque! Put your 2.0L cross flow on steroids and have some fun! Latest BBM4201 Software Updates Included, compressor unit capable of up to 300bhp
    sounds good, cross flow engine tho...
    Sep 2006
    West Sydney
    Quote Originally Posted by deemoIII View Post
    Heard of lots of failures with these too, not sure exactly what though. Warranty is a bit of a tricky one too - most end up spending twice the amount getting it fixed or a replacement. Heard that the Neuspeed s'charger is more reliable though. Again, my knowledge in this is totally from reading other forums.
    <Nick the greek> Dunno looks expensive... <Nick the greek>
    Oct 2005
    Would the Bahn Brenner MK2 type not fit the MK3 8V ?
    MK2 GTI G60
