Results 1 to 5 of 5
Thread: fifth injector
    Oct 2006
    sydney
    fifth injector
    i was on the web and found a thread in reference to installing a fifth injector, it was positioned before the throttle body butterfly it would require a hole drilled enough for the injector rubber gromit to bed into, an injector a conector plug and section of the loom has anyone seen or done this?
    Camden, Sydney
    wouldn`t that be a 7th injector for you mate? You could prob set that up with the microtech on your car
    May 2006
    byron bay area
    Quote Originally Posted by william
    I have heard of the existing cold start injector (K-jet) being incorporated to the super charging switch. So when you hit the switch the fith injector becomes active
    Oct 2006
    sydney
    the thread was found on a peugeot 205gti forum in relation to a fifth injector setup on the throttle body pic attached would be good with a turbo setup on a four cylinder 2.0 golf engine with microtech
    I used the cold start injector on my MK1 to get more fuel. Using a box called a map fueller. Pretty crude but it worked a treat. Has a vac switch built in so it only injected when under load.
    The box could drive 2 injectors if required and you would drill them into the back of the inlet manifold, firing between 1 and 2, 3 and 4 for best distribution of the fuel.
    Reasonably easy to set up with a lambda reader to monitor the mixture. You could do it on the road easy enough. 6 or 7 settings based on revs, you could increase the duty cycle of the injector up to flat out to get the fuel you needed.
    With a pressure switch you could use it with a turbo too.
    PS looking for a link now.
    LINK found
    http://www.aquamist.co.uk/cp/mf2/mf2.html
Similar Threads
  1. Diesel injector pump seals
    By hiho in forum Diesels
    Last Post: 19-12-2010, 02:18 PM
  2. VR6 injector service
    By gman in forum Mk3 Golf & Vento
    Last Post: 19-12-2007, 10:14 PM
  3. Replies: 1
    Last Post: 02-11-2006, 08:05 PM
  4. Injector Pump Leak and movement - Main Shaft
    By hvellacott in forum Diesels
    Last Post: 28-09-2006, 07:20 PM
