DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Few mods Golf GTI MKV - Need recommendations and help
    Oct 2010
    Quote Originally Posted by aDg3 View Post
    Decided not to get an exhaust done this time around as it provides minimal KW gains (awesome sound though).
    The downpipe is where you'll liberate more power, especially in conjunction with an ecu reflash. If you don't want much more noise (increased noise from a downpipe alone seems to vary from brand to brand based on comments in other threads on the forum) then I'd consider a downpipe only upgrade, bolted onto the stock catback exhaust. If you're going with all APR gear, they would have a downpipe to suit...
    MY07 GOLF GTI
    5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
    Point Cook, Vic
    Go see Arthur at Exoticars in North Paramatta.
    Downpipe is the biggest gain you can get after the initial tune.
    GIAC ECU flash - $995
    BCS carbon airbox intake - $599
    Eurojet downpipe - $799
    Dont waste money on a forge diverter valve. They get sticky after a while and require maintenance. No real benefit over the OEM revision D piston style unit. You can use a forge spacer to get your blow off noise without the forge DV.
    FOLLOW US ON FACEBOOK
