Screamers are great fun!
I would recommend getting an aftermarket manifold or having a custom one made.
Although you can weld a flange to the original manifold it would more than likely crack around the weld because the factory manifold casting requires a welding proceedure with appropriate preheating and surface preperation.
Have you seen just how small the factory ports are in the manifold? They are tiny and restrict power but enable quick response and boost.
