DNA Tuning (Australia)
Results 1 to 10 of 15
Thread: external wategate
    external wategate
    how do u weld or bolt one up to the stock manifold on a 1.8T?
    wanna run a screamer on a 38mm gate with like 17psi spring so it opens up on high psi.
    Jun 2006
    Orange NSW
    Screamers are great fun!
    I would recommend getting an aftermarket manifold or having a custom one made.
    Although you can weld a flange to the original manifold it would more than likely crack around the weld because the factory manifold casting requires a welding proceedure with appropriate preheating and surface preperation.
    Have you seen just how small the factory ports are in the manifold? They are tiny and restrict power but enable quick response and boost.
    Mk2 GTI 2 door 1.9l 8v turbo 1st mk2 1st engineered water vw nats 09
    Mk1 twin eng twin turb
    scirocco gti 2.1l 16v turb 6spd
    Audi A4 B5 1.8t
    wot about the internal gate? simple weld closed?
    der are manifolds on ebay but they dont look very tough..
    I want a screamer on my 124 16v turbo...but ill be running around 25psi
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
    Oct 2006
    i see this car getting a yellow birdie very soon, maybe 3.
    Feb 2007
    Quote Originally Posted by fuzion View Post
    3 x the fullysicness!
    I love screamers, there was a F6 FPV at the "drags" that was leaving the road white from the flames, i was like what idiot puts a neon there till i realised it was the wastegate haha.
    MK1 GLS 3door
    A4 B7 2.0T
    Jun 2006
    Orange NSW
    Quote Originally Posted by AGO41T View Post
    You could weld the internal gate closed but i really would not recommend doing it, once its welded up you have to live with the results. Which may be more boost than it is tuned for, boost spikes and damaging the turbine and compressor wheels.
    Your right about ebay manifolds, most are manufactured from thin walled stainless steel and crack!
    Audi A4 B5 1.8t
    Jan 2008
    I believe internal gates' are usually closed. So you dont have to weld it shut, it will just stay shut if the actuator is not operating.
    how to leave the actuator not working?
    i mite buy a used manifold and use a ext gate and try it..
    Jun 2006
    Orange NSW
    If you disconnect the hose going to the wastegate actuator it will make a lot more boost. The hose sends boost pressure to the back of the actuator diaphram pushing the diaphram, rod and finally wastegate open. With the hose disconnected the wastegate will only open when the back pressure in the exhaust manifold is enough to push it open. This could happen at anything up 30psi even, but i wouldn't recommend trying to find what the maximum it makes is...
    Audi A4 B5 1.8t
