That sounds quite large. What size engine is it? If you dont have enough backpressure, you`ll lose heaps of go. I`m thinking 2.5inch for my 2L 16v
That size with a 1.6 would be no good though.
With my 1976 3 door golf which i am doing up to race, i was thinking of a 2 1/4inch stainless steel engine to outlet system. does anyone know what the 'right' kind of exaust and back pressure is needed for best performance![]()
yeh sorry i forgot to say... its a 1600 carby.... yeh i think ill just leave the stock piping in there and put on a new muffler... do you think that will work at all?
that again is my post i keep forgettting to log inOriginally Posted by Anonymous
Has it got extractors? They make the 1600s howl, especially if you drill out the main jet in the carby, or replace it with an auto one.
no i havent got extractors atm... stock as a block . but i have a carby that i got off my renault 15 (which is going to wreckers tommorowcos it has so much rust) and the carby is a double barrel (both barrels 41mm ) webber.
but the manifold bolt pattern doesnt match up. will i be able to fit this carbi on?
i was wanting extractors![]()
If you can cut and weld up a golf inlet manifold, you might be able to make it fit. i think its alloy though, hard to weld.
I`ve got some brand new extractors, which dont fit my 16v. 200bucks never been on a car.
well ill take my car to Volkspower to see what they can do, and to see if the carbi is worth putting on. im a Melbourne man. extractors you say?would they fit a mk1?
The extractors are made for a Mk1. I paid 300 for them, but have now got a 16v, so dont fit my car. Bargain $200 postage $40approx
Ill think about it.... thanks
