If the engine has extractors, a cam and a better carby. 100 if not, maybe 80?
jesus..i just got the 1600 8v engine... so ill get bout 100hp??? round bout? at the flywheel
extracors cam and exaust are next on the list![]()
The HP readings in the Golfs case, do not reflect the speed and handling. Its the whole package and I LOVE IT.
my dellortoes should make it go like stink... i agree. cos its such a light car with direct steering.. a great package.. i love it also soo entertaining to driveOriginally Posted by Golf Loon
cant wait to get some sport suspension improve handling further
If it was that easy, many tuners would be out of a job. I could write you out a list several pages long for getting 200hp from a 1.8 8v engine.Originally Posted by gldgti
It is difficult enough to get an HONEST 200hp from a very modified 2.0 16v. :roll:
Not a chance my friend. To get the Golf 3 8v head to flow any CFM requires 41mm inlet valves and some very serious workOriginally Posted by Belgianwaffler
VanKronenburg how much power would i get when i strap on my doubble barrel dellortoes onto my 1.6 8v??
Perhaps 5-8ps... Remember that when you give an engine the opportunity to breathe more air it must be capable to do so, otherwise the power gains are very small. So if you install twin carb or throttle bodies to any motor, you need to upgrade the camshaft to allow the air to enter. Then, you must also upgrade the head to get the best from both the carbs and the cams and generally to restore midrange torque. Placing induction mods on a standard motor will flatten the torque curve more than it will add power. It will sound nice, though![]()
camshaft was next on my list of things to buy.
