Hi again for those who are interested and have the cash to play ....
I have just been searching for ways to improve power without force induction.
I'm in the process of finishing a 16v head with a valve swap;
33 mm intakes with 6mm stems, std 28mm exaust valves. the head is a 2.0l head which is reported to flow well on the exaust side.
There is no porting on the head except for the seat work which had to be done to accomodate the larger valves. ("radiussing" of the seats as well).
the valves (intake) are from a 2000 ford focus "zetec" engine and are the oversize option. at 97.5 mm long they are 2mm longer than std vw intake valves... the seats in my head were not recessed and I was able to check lifter clearance which was around 1.5mm... of course I had to get some valve guides made up as 6mm would be quite loose in the old ones..
VanKronenburg how good are the std 16v springs ???
