200hp with a single delorto 1.8 where did he hide the hair drier ????
on that exsaust issue, i had a full 2 1/4" fitted to me 16v mk1 with to hotdogs and a back box, unaware the back muffler was a cheapo the motor killed it, mounts were snapping and i slaughted 2 flex joints in 3 months ,rear muffler was getting crazy hot and eventually burnt the inside flanges off and a big lack of power was lost i had that muffler for bout 5 weeks befor it was dead, now its a 'superflow' straight through box with 3 " tip, ,instant power back really good choice.......
i never relilsed an exsaust could make that much difference to performance so shop around and ask lotsa question befor u get one made up and inpsect your hardware befor dodgy ass muffler men stuf your car up..
the golf is not dead.
He may have meant 100 hp I recon ,people love numbers.
isnt the rule of thumb 1/10 of your capacity is the peak power you can achieve naturally aspirated?? for eg 1600 is 160hp and so onOriginally Posted by TassieGTi
That rule of thunb may apply to factory developed big budget motor but a norm from the suburbs would be lucky to get 100 with that combo.Lets be realistic.
fair enuff i agree with that. if he put a blower on there he coulda got that sorta power though
I reckon 100 is realistic with that motor.
A supercharger or turbo would be fun though:twisted:
single dellorto will flow about 90 hp
from memory ....
now twin with bigger chokes that should be nice ...
wat will the twin do from memory??? is that 90hp just from fitting the new carbi?
with the twin delorttos you should see about 140 - 150 HP (flywheel) from a ported MK3 8v head (they had 7mm stems).
In Denmark my Uncle had a 16v with a 1600cc bottom end wich was pulling 213 HP flywheel at 8700RPM (twin delorttos) that was back in the late 80s
