Results 21 to 30 of 37
Thread: Engine Oil!
  1. #21
    Jul 2005
    Melbourne, Williamstown
    What I've been told is that VW OEM filters have a spring loaded pressure valve inside them which helps with things like hydraulic tappets and oil squirters. When they're 15 bucks per filter why bother the risk with another brand.
    I've got a Mk1 Gti style oil filter adapter for my 16v which has the fittings for an oil cooler rather than the original mk2/3/4 water/oil sandwich plate arrangement, also I'll be able to add an additional external oil filter which is never a bad thing.
    Haven't fitted it up yet, one of many jobs that comes when I have the Passat registered in less than a week.
    mk2 GTi 16v
    Corrado G60
  2. #22
    imported_brackie Guest
    Anti-fallback valve
    Quote Originally Posted by ausgolfer
    Some filters have a valve to prevent oil/fuel draining back when the motor isn't running. This is particularly important with inverted oil filters (like the one on my Pug diesel). But I was hoping for some technical comparisons such as micron gap, number of filter elements, type of material, capacity etc. Syncro? Anybody? I reckon if we make a statement like, "This one's better than that one..." we should be able to back it up with some technical information.
    Here's an American site that at least has some empirical evidence
    http://minimopar.knizefamily.net/oilfilterstudy.html
  3. #23
    Dec 2005
    Well I could drive 5 min up the rd and get a ryco or drive 30 min and get a OEM :roll:
  4. #24
    syncro Guest
    I've seen too many Golfs with rods through the block with non genuine filters.
    Why buy a Volkswagen and then slowly convert it?
    Filters also have overpressure valves. Different pressures for different engines.
  5. #25
    Dec 2005
    Quote Originally Posted by syncro
    Whos to say that thats because of the filter? Maybe it just because most have non genuine filters.
    I hardly think buying a non genuine filter is converting a vw to something else.
    Anyways, not much point in arguing over something that none of us have any proof over.
  6. #26
    Apr 2006
    Hobart,Tas
    I always use Mann filters. They are the original supplier of filters to VW. They are cheaper than original. After saying that, I service a lot of new VWs, where as I use genuine to avoid any later warranty hassles.
    Years ago we did a test on a 2L kombi and found that with the Ryco oil filter, it ran 12lbs less oil pressure than with a Mann filter. Ryco can occasionaly show signs of leakage too I have noticed, also sometm es getting a bit loose later on.
  7. #27
    syncro Guest
    Quote Originally Posted by worm
    Out of around ten deceased engines, eight had Rycos and the other two were white filters (brand unknown). Most Golfs that I have seen in Sydney have OEM or genuine filters.
  8. #28
    Apr 2006
    VW Race HQ - Sydney
    Try pulling off a no name brand oil filter off a 2.5 transporter then get back to me .
    Ive seen cars not run using aftermarket filters . Im strongly against it . Its as bad as running the wrong heat range plug . Its still gonna run , but it aint gonna run right and eventually stop . Its your engine your risking not mine
  9. #29
    Golfwise Guest
    Its like your kidneys ,healthy ones and you will live forever .
    Filters and quality oil is most important.
    I serviced one particular mk1 Golf for over 20 years and it always had top quality oil and a genuine or Mann filter and at 430 k was running like a clock but needed the valve guides doing.
  10. #30
    Nov 2005
    Cool, Just wondering what engine oil is suitable?
    Because when I read the service manual, it said VW500 00?? What does that mean?
    There are this table saying 5W-30, 0W-40 SAE?
    Cheer,
    Fred.
    ...BiG DuB...
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. Running in a new diesel
    By brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 30-01-2009, 10:29 PM
  3. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  4. Replies: 16
    Last Post: 03-07-2007, 10:31 AM
  5. Gen 3 TDI engine conversion
    By dieseldude in forum Diesels
    Last Post: 13-04-2007, 04:17 PM
