Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Engine mods
    Apr 2006
    VW Race HQ - Sydney
    Engine mods
    List your engine mods here
    Audi S3
    Del rio big turbo kit
    Gt28 , custom fabricated dump pipe
    relocated lambda probe
    custom intake pipe
    modified standard airbox
    GFB dv
    stock n75
    s4 Maf
    split system cold air intake incorporating factory and custom design
    standard air filter
    modified air ducting for intake manifold / radiator
    Phonelophic spacer
    modified standard intake manifold
    580cc injectors
    3 bar FPR
    3 inch high flow cat
    And for the drags :
    20 psi spike at 22 (set at 16 for the street )
    VP109
    Straight 3 inch pipe after Cat
    Only other real mod to the engine at a later date will be air-water intercooler
    Run a best of 12.6 @ 113 mph
    Seat Ibiza GTI
    Oettinger chip
    pod (fitted when I bought the car)
    2 1/4 cat back exhaust
    planned
    give the car to my sister in law
    Audi S4
    Chip
    planned
    exhaust
    Golf VR6
    Too much to list
    planned
    1000-1300 hp + possibility of a NOS shot , see how it all goes , car is getting rollcage done now
    Jul 2005
    Melbourne, Williamstown
    Nice list there Seb,
    My
    Mk2 KR 16v,
    Non standard rear muffler
    K&N panel air filter replacement
    Time at the track.... well we'll see how the old girl goes if I can make it to calder on friday night. Honestly have no idea how it'll go, as long as I'm quicker than all the air cooled beetles I'll be happy
    Well my mum thinks it's fast and cool
    Wooot
    mk2 GTi 16v
    Corrado G60
    Oct 2005
    Nowra, NSW
    1000-1300hp vr6!!!! wow man
    8V digi 1.8 engine.
    No real mods to date, will have a worked head and 270 cam soon and a k&n filter for starters.
    gpk_gti Guest
    nothing like bug_racer im afraid...
    k03s (off god knows which car,it was free)
    2 3/4" ceramic coated custom dump pipe
    high flow cat
    2 1/2" mandrel bent custom exhaust pipe
    silencer removed
    MTM 1.8t stainless steel muffler
    MTM chip(rated to 232hp)
    K&N panel filter with airbox mod
    FORGE dv
    FORGE turbo inlet hose
    FORGE side mount intercooler
    n75 race valve
    and a few other bits to come...
    Jan 2007
    2006 MKv GTI
    APR Chip
    mods 2 come.....Carbonio CAI and APR TBE
    thats about it ........seb you need to take me for a spin in your GTI.....oh and tell Dragan i will prob drop by this Saturday 2 say hi and buy that short antenna for the GTI
    ::APR TUNED::BMC Filter::EVOMS Intake::FK Angel Eyes::MTEC Xenon KIT::R32 Taillights::Colour Coded Bumpers::Sharan Antenna Replica::18% TINT::
    Oct 2006
    sydney
    mods
    seat ibiza gti
    2.8L vr6 engine early distributor type
    k&n filter pod wish to change to to bmc filter
    2/1/2 inch exhaust right through highflow cat
    microtech engine management LT-18 hand controler mounted in the glovebox
    two chanel tune function tuned by adam at jem
    vr6 later model discs front and rear
    wheel spacers to widen track
    lowered eibach springs
    as is 100kw has hit 14 flat down a quarter
    plans to fit schrick inlet manifold ,port and polish head ,eip cams,superchange vf kit,bigger disc dilled and slotted,ebc greenstuff pads,
    Gosford Central Coast NSW
    for the funnies...
    my 1.5 diesel:
    tweaked injector pump for more fuel
    modified standard airbox 80mm inlet with direct behind grill cold air intake
    large 8v exhaust manifold 4 into 2 1.75" into 1 2.25" with genie turbo rear box
    injector timing advance....
    just to keep hte laughs going...
    est +8hp atc, up to a whopping 58hp or about 40kW.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jun 2006
    Orange NSW
    1985 Golf GTI 2 door 1.8litre 8 valver
    Engine Mods
    Wiseco Teflon Coated Forged Pistons 9.0:1 Comp
    Scat Forged Rods
    Eurospec Forged Crank, Knife Edged
    Extensively lightened flywheel, Alluminium Pulleys
    Hollow Stainless 250 Gram Intermediate Shaft
    Shrick 272 Degree Cam
    Ferrea Valves 42mm inlet, 35mm exhaust
    Extensive Porting, Polishing of head and manifolds, flow benched
    Fully Balanaced and Blue Printed
    IHI VF22 roller bearing turbo 18 psi boost
    Full turbo back 3" exhaust
    Custom watercooled exhaust manifold
    780 by 450 by 65mm front mount intercooler with 2'' to 3'' stainless pipe work
    Enlarged sump with baffles 5.1 litre capacity, 2 Litre Surge Tank
    EMS Stinger Engine Management
    EVO 5 injectors
    16 valve gearbox with 80% lock ( number 5... )
    Billstein Shocks, Jamex Springs
    256mm 16 valve brakes, ( to be upgraded soon )
    17" DTM's daily, 15" semi slicks for fun!
    Wheel spinning MONSTER! 186kw at the wheels, no grip till 3rd gear.
    12.9 sec Quarter 118mph
    Will hit 7500rpm in fifth gear....
    Oct 2005
    Nowra, NSW
    what a monster! bring it to the nats!
    Camden, Sydney
    Quote Originally Posted by static1800 View Post
    Yeah i`ll second that. Hope to see you there Marty.
Similar Threads
  1. VW Engine Number Chart
    By Golf Loon in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 14-09-2009, 03:20 AM
  2. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  3. Replies: 16
    Last Post: 03-07-2007, 10:31 AM
  4. Gen 3 TDI engine conversion
    By dieseldude in forum Diesels
    Last Post: 13-04-2007, 04:17 PM
  5. Next Engine Mods
    By golfnutracing in forum Mk1 Golf
    Last Post: 06-08-2006, 12:14 AM
