DNA Tuning (Australia)
Results 1 to 7 of 7
Thread: engine mod help
    babyboy16v Guest
    engine mod help
    Hi guys-
    need some help and advise please
    i recently built a 2 ltr 16v motor with high comp pistons - throttle bodies- head and cam job-
    KW output on the front wheels was 145
    i have just sold that motor and now building a 2 ltr 8v
    what need help on is what piston can i use to get the compression up and to make good power
    the head is gas flowed and ported and the cam is cut to 288 deg.
    some help please
    thanks
    Jul 2005
    Why are you going backwards?
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Oct 2005
    Nowra, NSW
    Im wondering that myself.. why drop the 16v for an 8 valve?
    Sunny Coast - The QLD
    Talking
    Quote Originally Posted by aprr32 View Post
    Funniest thing I have seen on for the last 12 months! Nice one.
    MK1 floG soon to have 16v 2L with cable change gbox - need a 16v turbo manifold
    "Fit the gearbox ya bum." Loon - best post ever!
    Aug 2006
    Melbourne VIC
    R u going to be running pump full? Fuel injectored or cardbies?
    Bit more info... Oh and BTW backwards step
    Jun 2006
    Orange NSW
    Hey dude,
    You are much better off to deck the head rather than use high comp pistons.
    The domed crown tends to cause detonation because it causes the flame to burn towards the outer edge of the cylinder.
    Use standard pistons and talk to an engine shop about taking a bit off the head. They can work out how much is needed to be taken off.
    If you want to run pump fuel, i'd suggest not going any more than 11.5/1 comp.
    Why an 8v though? I mean seriously.
    Oct 2006
    Say u get the head skimmed what are the options then if u want to go turbo? Does that mean custom pistons (rather then off the shelf stuff) will have to be the way to go then?
