Results 1 to 2 of 2
Thread: Electric low pressure fuel pumps
    Feb 2006
    Devonport, Tasmania
    Looking for peoples experiences with low pressure fuel pumps. For carburetor applications. Specifically, multiple carburetors.
    Im using a Carter low pressure/high volume pump rated at 3/4 psi. Im not really happy with it. I find it too loud and think it may be pumping too much, even though they dont recommend using a regulator with it. Have yet to measure the actual amount of flow the pump has.
    What are you guys running, recommend or had great/terrible experiences with?
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
    Sep 2011
    I've used Holleys, they had two versions for low pressure applications (Red & Blue for different pressures), they were noisey and mounted externally to the tank, but this can be reduced by mounting the pump in a way that it will reduce vibrations. I mounted mine to an old engine mount which reduced the noise a fair bit. AlthoughI should add this was 20 odd years ago and on a 70s Ford so I suppose the term noisey is relative to the vehicle/user/era. A regulator is recommended with these pumps.
    MY11.5 6R GTI 3 DOOR
