DNA Tuning (Australia)
Results 1 to 5 of 5
Thread: MAF grille removal - How to?
    Bowral, NSW
    Hey, guys!
    Everybody always goes on about how they've removed their MAF grille... But I can't find any details on how to do it.
    I can't see any clips or anything. Almost got the fine-toothed saw and started hacking away but throught better of it.
    Any help would be appreciated!
    Cheers,
    -Myst.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Apr 2012
    Victoria, S/E
    +1, im also interested
    EDIT: look at poyta's build, early on its explains how to do it but looking at yours they must have changed it slightly too the golf... i saw mine today and noticed its the exact same as poytas but not yours.
    Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
    Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
    Are you sure you want to remove it? Whats the reason? The grill is actually there to "straighten" the air before the MAF which helps the engine run better.
    Removing it may have a negative affect.
    Apr 2012
    Victoria, S/E
    It has a negative effect when you have the stock intake but i believe he has a Carbonio which is a straight air intake hence no need for the maf.
    But i could be wrong im just going off what i read.
    Bowral, NSW
    Yup!
    Sexy sexy Carbonio.
    Mainly want to remove it for the noise. If the removal is non-destructive then all the better - I have a Bluetooth OBD scanner and Torque Pro on an Android tablet (see sig) so can monitor the MAF flow. If its altered too much I'll just put the grille back and warn everybody.
