DNA Tuning (Australia)
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: ECU tune and emission requirements
    Oct 2012
    NSW
    Hi,
    I recently enquired with a highly regarded tuning firm about the effect an ECU tune may have on meeting Australian exhaust emission requirements. The reason I asked them was because my insurer tells me they are happy to insure any modification to my vehicle so long as the modification would pass an RTA inspection (i.e. It needs to be fully compliant and legal).
    Given that a high quality ECU tune will be adjusting amongst other things AFR, timing and boost pressures, I think the question is a reasonable one. A quick Google search brings up a number of stories regarding vehicles with modified ECU software failing an emission test. Often in these cases the owner had to reflash the ECU back to stock to pass the test.
    It is further comcerning to me that possibly no customers would have needed to have an inspection yet in the case of my particular vehicle, since the model only first came out a few years ago and the associated tune that I was thinking of purchasing came out in 2011.
    So for anyone who has had their VW's ECU software modified, have you since had an RTA (or whatever the relevant body is in your state) inspection and passed emissions testing with that modified software? If so, what tuning company did you use and did the tuning company have some sort of certification that the tune maintained the same emission standard (or better) of the stock vehicle?
    Thanks
    MY13 Polo 77TSI manual transmission Comfortline in Candy White - "Herr Marco"
    Hi JonP01
    Thought I'd answer this as Viezu is the world leading authority when it comes to emissions reduction mapping services through our Blue Optimize services...
    This probably tells you all you need to know:
    Happy to answer any questions - if you like please Email me directly - simon@viezu.com.au and we can go through it all in detail.
    Thanks v much
    Simon
    http://viezu.com.au/ VAR Design. Exclusive Viezu distributors and developers for Oceania.
    Some of the best locally developed VAG tuning options on the market now released for ECU and DSG along with some of the best quality and value exhaust ranges /CAI's in Oceania. Put us to the test - 100% satisfaction money back guarantees.
    Here is some reading for you - it's from 2008 but is still relevant today. The new NCOP does not alter it.
    Engineer's certificate for remap ?
    Basically the roadside tests (which is where most cars come under scrutiny) where they use a "tailpipe sniffer" will need to see good efficient catalyst installed (200 cell has been known to pass these tests, 100 cell has been known to fail).
    A quality remap and no other mods, you shouldn't have an issue.
    Let us know if you need further information.
    I
    Oct 2012
    NSW
    Thanks very much for the replies and in particular the link to the engineer's certificate thread. My searching did not being up that thread, so I appreciate that very much.
    I think after reading all of the relevant material I have decided that ECU tuning is not for me. I wanted the most powerful manual transmission Polo available but unfortunately that is only the 77TSI model. I would have happily bought a more powerful model if VW actually sold such a car, it had a manual transmission and still had the same size wheels and tyres and suspension as mine (for comfort). Not likely that such a car would ever be sold in this day and age though. It seems if you want a very small performance car these days (4 metres in length or less) you have to have a "sports" suspension, undertrays or bodywork that scrapes the road surface every time you go into or out of a driveway and huge wheels with tyres that barely hold any more air than a baby mouse's lungs. I guess there just isn't a specific new car market for people like me. I am 25 years out of date
    Thanks again
    Bowral, NSW
    Buy a sports model, and offer to swap out the springs with someone who has the standard model - people are all over things like that!
    Springs and rims/tyres, you can probably even get cash your way.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Oct 2012
    NSW
    Quote Originally Posted by Mysticality View Post
    Prima facie that is a very logical and sensible suggestion. That could, however, conceivably be even more of a legal and practical minefield than an ECU modification. Bottom line is I would have to be somewhere between amazingly keen to outright desperate to try that. If you go to the VSCCS section of the RTA website and download the documentation relating to wheel and suspension modifications, one would have to be incredibly keen and highly knowledgeable to pursue that avenue and end up with a properly certified car that was as safe as the original. It needs to be remembered above all else that a high performance car requires a suspension, wheel and tyre package designed to cope with the engine power. It is very likely that "downgrading" the suspension, wheels and tyres to make the car much more comfortable may infact make the vehicle less safe, even if it managed to still meet the VCSSC legal requirements (which are strict enough as it is).
    The VSCCS documentation is very technical and I personally would not want to attempt something like that unless I was highly experienced. It would be far easier for me to simply build a garden shed, thereby liberating the extra space in the garage so as to fit a manual Falcon 6 cylinder turbo in there, and then tell my Mum that she will have to pick me up and drive me to her house for the weekly visits, since the Falcon can't be safely parked in her street and won't fit in her driveway (her street is literally slightly wider than a driveway but still two-way, which was the main reason I had to stick with a car no bigger than a Polo).
    Anyway, the RTA website also seems to make it pretty clear as to what can be changed on a car without requiring an engineer's certification. NCOP3 1.2 states that a modification requires certification in the instance where:
    "....Modifying the engine and engine components (that) results in an increase in engine power
    of more than 20% and/or affects exhaust emissions...."
    So, in respect of the Polo 1.2 TSI, any ECU modification that results in a maximum power output of more than 92.4 kilowatts for the Polo 1.2 TSI requires an engineer's certificate for that individual vehicle. So in NSW, for instance, the Stage 1 DNA Tune (100 kW) requires an engineering certifcate. No ifs and no buts. It is crystal clear written in black and white (well, with a bit of blue thrown-in too). One might try to argue that they had a "great" engine to begin with and it already had 84 stock kW (meaning the power increase would be just under the 20% limit). But I doubt the law would see it that way, since in the absence of any pre-existing individual tests for that car, they would simply take the manufacturer's quoted output as a starting point.
    The only gray area so far as I am concerned would now seem to be what the word "affects" means. The RTA could have used the word "increase", but they use the word "affects". To me, "affects" means cause a change. Which really means anything done to the ECU needs certification, even if the tune does not increase power beyond 20%. Though I think even I would likely sleep at night if, for instance, I bought a tune that improved fuel economy, since I could not see for the life of me how that would make the emissions worse, but then again I am not an emissions engineer.
    So, who can tune a Polo 1.2 TSI to 92.399999 kw and not a smidgeon more? Sort of makes the whole idea a pointless pursuit unless you can buy a tune that guarantees better fuel economy, smoother performance, no flat spots, much better torque, but no more than 92 kW of power. I don't think many of the tuning companies would even consider offering such a "modest" product, since they would probably think their customers would expect more for their money.
    Incidentally, I have emailed a certified VSCCS engineer just to ask him what the procedure for certification would involve in these cases and how much it costs. He will probably laugh at me and not even reply (which is fine, better to ask a dumb question that pretend I know the answer and continue to be ignorant). But if he replies, I will try to report what he says if appropriate. At least these engineers are not hard to find and the RTA make it easy to locate one who is local to you. But with emissions testing, there are apparently only a few places in NSW that can do it, although there is a statement in the VCSSC documentation stating that the RTA are attempting to create a simplified "5 gases" test that is far more widely available (that update was in September 2012, with no further updates since then).
    Oct 2012
    NSW
    Interesting...I just found an alternative product for the Polo - the BSR tune. It is more conservative at 91 kw, thereby coming in under the VSCCS threshold by 1.4 kW (but produces a nice torque increase of 24 nm). It is as if BSR are aware of the legal issues and have deliberately made the tune conservative so as to avoid certifcation hassles and expenses (the certification can otherwise add anything from $600 or $1,000 upwards to your ECU tune costs in the event power increases by more than 20%).They will also take over the engine and power train warranty.
    I then rang the VSCCS hotline to confirm my way of thinking and I am correct - there is no certifcation required for the BSR tune but certification is required by any tune producing more than 20% power over stock. I then asked about the emissions and they said in this case, so long as I do not physically remove or alter any of the physical emission contros, everything is fine.
    Newcastle, NSW
    In all honesty, unless you are trying to do Maccas tray drifting then no police officer will look twice at your car.
    Ergo, you are getting unduly concerned over nothing.
    Audi S3. Sold
    Golf R. Sold
    Citroen DS3 Dsport. Sold
    2016 Skoda Octavia RS Wagon.
    Gotta agree with the guys here. You're not going to get looked at twice in a 77TSI Polo. You're as likely to get defected for emissions on that thing as a Prius is. :p
    Sent from my GTI using Tapatalk.
    Quote Originally Posted by Ideo View Post
    +1 way overly concerned over nothing mate. Cops dont even look twice at modded GTI's and R's so a humble Polo 77 isnt even going to raise an eyebrow. Cant go wrong with the 100kw tune from DNA either.
