Originally Posted by
JonP01
I am well aware of all the principals you mention, however my previous Mazda was the last revision of the "old" 1.5 litre engine in which the torque was improved down low and the torque curve considerably flattened out in comparison to the 1.5 litre models built prior to early 2006. My model was the shortest lived of all the Mazda 2 revisions - think it sold here for only 6 to 8 months at the most from early 2006 to late 2006. I remember looking at a torque graph for the last of the 82 kw engines that mine was equipped with and it was virtually flat from between 3400 and 4000. Maybe there was about 5nm difference across that part of the rev range but that was about it.
So my point is that at freeway speeds, the Mazda was infact delivering practically the best of its torque in 5th gear give or take literally a small handful of nm, and the Polo in 6th gear is doing the same. Even if I am generous and say the Mazda was only delivering 130nm of its maximum 142 nm torque at 110 kmh (and from memory it was more than that in 5th gear), then take 50 / 33 * 130 and you get 197 (the 50 is the kmh per 1000 in 6th - top gear - for the Polo, the 33 is the kmh per 1000 in 5th - top gear - for the Mazda). And yes, the Mazda was definitely less aerodynamic than the Polo, but I still get 197 versus 175. Maybe that 22 nm variation can purely come down to aerodynamics and drive train losses, however I think they can only account for part of the difference. So I think it is still likely that at least some of the 1.2 TSI engines are performing better in the real world than the figures put out by VW, because if I take the VW figure as an absolute, then the Polo in 6th gear would simply not be capable of outperforming the old Mazda in 5th gear when they were both at maximum torque. But the Polo in 6th gear infact outperforms the old Mazda in 5th when they are both running within the most advantageous part of their torque bands.
