Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: ecu swap+immo swap read,save+reprogram!?
  1. #21
    Sep 2014
    Tasmania
    ..and that's great, or do you mean not great?
    This isn't..! "Too many Excessive com errors to continue" reading the ecu, no fault codes found for a removed airbag and no light...??thats odd and there's black gunk in the vacume tube to the motorola in ecu. Won't start still.
    In an effort I Changed starter solenoid (the last suspect)but no kick..also checked power from ignition to starter which it has but drops out when turned...this mightily sounds like the distributor hall senders gone (and have replaced this 4 times so far ((AU$130 a time))).
    I'm out of ideas.
    Thanks for everyone's input, anyone now know how to get into the contents of the other ecu?
    Maybe recode it?
