Originally Posted by
Corey_R
The DSG is rating the same as the manual gearbox is rated. Just as there are standard manual gearboxes in Golf's running around with 500Nm+ torque, there are standard DSG's running around in Golf's with 500Nm+ too.
If you're doing 1/4 miles or traffic lights GP's all the time, then yes, you're going to have trouble. Trouble with the DSG, trouble with a manual. If you've got decent mechanical sympathy, you're fine.
Either way, DSG or manual, you've always got the option of upgrading the clutches and diffs to handle the additional power and standing-start abuse if you'd like. The DSG also has varies "Stages" of software flashes to handle additional power and torque, as well as aftermarket clutch packs...
